![](assets/images/logos/Gateway.png)
Gateway Administrator Guide
Version 5.4 | Published March 22, 2022 ©
MOS Protocol Support
MOS Profile Support
Gateway supports the following MOS profiles:
Profile |
Definition |
Supported |
Vizrt Comment |
0 |
Basic Communications |
yes |
1 |
Basic Object Based Workflow |
yes |
2 |
Basic Running Order/Content List Workflow |
yes |
3 |
Advanced Object Based Workflow |
partly |
Only mosItemReplace is used. |
4 |
Advanced RO/Content List Workflow |
yes |
5 |
Item Control |
partly |
Only roCtrl is supported. |
6 |
MOS Redirection |
yes |
7 |
MOS RO/Content List Modification |
no |
Gateway supports these MOS protocol versions:
Protocol version |
Supported |
2.6 |
yes |
2.8.0 |
yes |
2.8.1 |
yes* |
2.8.2 |
yes* |
2.8.3 |
yes* |
2.8.4 |
yes* |
2.8.5 |
yes* |
*Both the Media Sequencer hosting the central Gateway and Media Sequencer clients must be upgraded to version 5.3 or later to support MOS Protocol version 2.8.1 or later. |
For more information about the MOS protocol, see mosprotocol.com.
