Version 5.5 | Published July 22, 2024 ©
MOS Object with Clip Templates Merged in a Mosart Template
A single MOS object is created for all Mosart templates of type PACKAGE or VOICEOVER from the default template set. In this example:
<mosExternalMetadata> node contains the list of variants for the Mosart templates of type PACKAGE and VOICEOVER.
<objID> of the MOS object is set to 25, representing a Mosart item type CLIP.
<objGroup> is the default template set name.
<type> node has name and category set to “CLIP”, and templateset set to the name of the default template set.
The variant for each template is built using some prefixes:
1) for PACKAGE, the variant is set to MAZ-<template variant>
2) for VOICEOVER, the variant is set to OFFMAZ-<template variant>
Note: When GroupByType is false, no MOS object will be sent for templates of type PACKAGE and VOICEOVER.
<mosObj><objID>LOWERTHIRDS</objID><objSlug>LOWERTHIRDS</objSlug><mosAbstract /><objGroup>TEMPLATES</objGroup><objType>STILL</objType><objTB>50</objTB><objRev>1</objRev><objDur>0</objDur><!-- The status of the MOS object can be NEW, UPDATED or DELETED --><status>NEW</status><objAir>NOT READY</objAir><createdBy/><created/><changedBy/><changed/><description /><mosExternalMetadata>      <mosScope>PLAYLIST</mosScope>      <mosSchema>http://www.mosartmedialab.no/schema/mositem.dtd</mosSchema>      <mosPayload>         <mosarttemplate>      	<type name="LOWERTHIRDS" category="GRAPHICS">        	<variants fieldtype="LIST" value="AUTOOUT">          	<variant name="AUTOOUT">            	<fields>                  <field name="graphics_description" fieldtype="TEXT" />                         <field name="graphics_id" fieldtype="TEXT" />                        <field name="tc_in" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00"/>                       <field name="tc_out" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00"/>                       <field name="channel" value="DSK" fieldtype="LIST" keylist="channels" />                       <field name="take" value="AUTO" fieldtype="LIST" keylist="taketypes" />            	</fields>          	</variant>          	<variant name="KEEPWHILEBACKGROUND">            	<fields>                  <field name="graphics_description" fieldtype="TEXT" />                        <field name="graphics_id" fieldtype="TEXT" />                       <field name="tc_in" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00" />                        <field name="tc_out" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00" />                        <field name="channel" value="DSK" fieldtype="LIST" keylist="channels" />                         <field name="take" value="AUTO" fieldtype="LIST" keylist="taketypes" />            	</fields>          	</variant>          	<variant name="KEEPWHILESTORY">            	<fields>                    <field name="graphics_description" fieldtype="TEXT" />                           <field name="graphics_id" fieldtype="TEXT" />              	         <field name="tc_in" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00" />              	         <field name="tc_out" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00" />                          <field name="channel" value="DSK" fieldtype="LIST" keylist="channels" />              	         <field name="take" value="AUTO" fieldtype="LIST" keylist="taketypes" />            	</fields>          	</variant>          	<variant name="NONEAUTOOUT">            	<fields>                    <field name="graphics_description" fieldtype="TEXT" />                           <field name="graphics_id" fieldtype="TEXT" />              	         <field name="tc_in" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00" />              	         <field name="tc_out" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00" />                          <field name="channel" value="DSK" fieldtype="LIST" keylist="channels" />              	         <field name="take" value="AUTO" fieldtype="LIST" keylist="taketypes" />            	</fields>          	</variant>        	</variants>            <!-- List of active channels (graphics destinations) as configured in OverlayGraphics Interface-->        	<keys name="channels">          	<k>WALL_2</k>          	<k>WALL</k>          	<k>TABLE</k>          	<k>DSK</k>  </keys>          	<keys name="taketypes">          	<k>AUTO</k>          	<k>MANUAL</k>        	</keys>      	</type>       </mosarttemplate>    </mosPayload></mosExternalMetadata></mosObj>The list of channels contains the active destinations (destinations linked to a graphic engine) as configured in the Overlay Graphics interface.
For details of configuration, refer to section xxx.
