Version 5.5 | Published July 22, 2024 ©
te_template
The table te_template contains the individual templates with information that is shared among all galleries.
Note that information regarding a single template is divided into three parts / tables:
te_template: Contains basic template information. This information is shared among all galleries (i.e. gallery independent).
td_templatedescription: Contains typically template information to be presented to users that is gallery dependent.
ti_templateimplementation: Contains the template implementation as created by the Mosart template editor. This information is gallery dependent.
         Name  |
         Type  |
         Allow Null  |
         Description  |
         te_recno  |
         integer  |
         No  |
         Primary key.  |
         te_ts_recno  |
         integer  |
         No  |
         Foreign key referencing the corresponding template set in the ts_templateset table.  |
         te_tt_recno  |
         integer  |
         No  |
         Foreign key referencing the corresponding template type in the tt_templatetype table.  |
         te_variant  |
         varchar(32)  |
         No  |
         The Mosart template variant.  |
         te_description  |
         varchar(128)  |
         Yes  |
         Optional template description.  |
         te_hidden  |
         smallint  |
         Yes  |
         Set to true (1) if this template is to be hidden from any user presentations.  |
         te_name  |
         varchar(128)  |
         Yes  |
         Optional template name.  |
         te_sendtoncs  |
         smallint  |
         Yes  |
         Set to true (1) if the template implementation is to be sent to NCS. Used by some NCS only.  |
