Version 5.5 | Published July 22, 2024 ©
ta_templatetypealias
The ta_templatetypealias table contains custom user aliases for the Mosart template types. These aliases are used by Mosart ManusAdministrator to translate user aliases to the corresponding Mosart template types.
         Name  |
         Type  |
         Allow Null  |
         Description  |
         ta_recno  |
         integer  |
         No  |
         Primary key.  |
         ta_name  |
         varchar(32)  |
         No  |
         The template type alias name. Should be unique, as this is presented to the users.  |
         ta_description  |
         varchar(128)  |
         Yes  |
         Optional template type alias description.  |
         ta_tt_recno  |
         integer  |
         No  |
         Foreign key referencing the corresponding Mosart template type in the tt_templatetype table.  |
         ta_default  |
         smallint  |
         Yes  |
         A value of 1 is used for the ‘default’ alias among those belonging to the same template type. For each template type, exactly one alias belonging to that type should have ta_default = 1.  |
Information: The ta_templatetypealias table is the only table that is maintained and used by Mosart ManusAdministrator containing the NRCS template type aliases.
