Version 5.5 | Published July 22, 2024 ©
ti_templateimplementation
The table ti_templateimplementation contains the gallery specific template implementation as created by the Mosart template editor (i.e. this information is gallery dependent).
Name
Type
Allow Null
Description
ti_recno
integer
No
Primary key.
ti_te_recno
integer
No
Foreign key referencing the corresponding template te_recno in the te_template table.
ti_ga_recno
integer
No
Foreign key referencing the corresponding gallery ga_recno in the ga_gallery table.
ti_xml
longtext
Yes
The actual xml-formatted template implementation as created by the Mosart template editor.
Information: The template implementation must be created per gallery and is stored using its native XML representation, as received from the Mosart template editor
