Version 5.5 | Published July 22, 2024 ©
td_templatedescription
The table td_templatedescription contains template information to be presented to users that may differ among the galleries (i.e. this information is gallery dependent).
         Name  |
         Type  |
         Allow Null  |
         Description  |
         td_recno  |
         integer  |
         No  |
         Primary key.  |
         td_te_recno  |
         integer  |
         No  |
         Foreign key referencing the corresponding template te_recno in the te_template table.  |
         td_ga_recno  |
         integer  |
         No  |
         Foreign key referencing the corresponding gallery ga_recno in the ga_gallery table  |
         td_tr_recno  |
         integer  |
         Yes  |
         Optional foreign key referencing a transition tr_recno in the tr_transition table.  |
         td_default  |
         varchar(128)  |
         Yes  |
         Optional default value for transitions not of type ENUMERATION. Normally for MIX and WIPE transitions.  |
         td_em_recno  |
         integer  |
         Yes  |
         Optional foreign key for the default value for ENUMERATION transition types. Normally EFFECT transition. Reference to a enumeration value em_recno in the em_enumerationmember table.  |
         td_descriptionupdateddate  |
         Datetime  |
         No  |
         (deprecated)  |
Note that the overall template description is stored in three parts / tables:
td_templatedescription: The base template description.
tr_transition: The transition used by the template. In Mosart this equals the transition when taking the template. Normally either Mix, Wipe or Effect.
tdfi_connection: Relation that list all fields (or newsroomtags) used by the templates. A newsroomtag is a template property allowing users to input information to the template. Normally newsroomtags are exposed to the users in the NCS.
