Version 2.1 | Published October 06, 2017 ©
Customer Support Requests
Support Requests are supported by Vizrt if customers have a valid Service Agreement in operation. Customers who do not have a Service Agreement and would like to set up a Service Agreement should contact their regional sales representative (see Customer Feedback and Suggestions).
When submitting a Support Request, relevant and correct information should be given to Vizrt Support, to make sure that Vizrt Support can give the quickest and best solution to your Support Request.
Before Submitting a Support Request
Before a Support Request is submitted make sure that you:
Read:
  • The relevant User Guide or Guides
  • The release notes
and Check:
  • That the system is configured correctly
  • That you have the specified hardware, tested and recommended versions
Always refer to your Vizrt Service Level Agreement document.
Note:
When completing a Support Request, add as much information as possible.
Content of a Support Request
The report should contain information about these topics:
  • Problem description: Include a good description of what the problem is and how to reproduce it. Specify your workflow. Remember to use simple English.
  • Screenshots and illustrations: Use these to simplify the message. These are extremely useful for Vizrt Support.
  • Software configuration: Add exact versions of software used. This is extremely important information.
  • System log files: Send the system log file.
  • System locale: Specify the Region and Language settings of the system.
  • Hardware configuration: Add exact versions of hardware used, especially for Viz Engine.
Optional:
  • System setup: Describe differences in the installation, if any, from the recommended setup.
  • System Network: Add a description of how the network, bandwidth, routers, and switches are configured.
To submit a Support Request
  1. On the www.vizrt.com page, click on Support.
  2. Click on Report a case.
  3. Click on LOG IN to log in to the Customer and Partner portal.
  4. At the top of the Case Management page, click on Report a Case.
  5. In the online form complete the required minimum information (shown by a red asterisk) and click SAVE.
  6. In the saved Support Case that opens, complete the various text boxes and upload any required documents, files, and so on (see Content of a Support Request).
To track the status of open support tickets, login to the Customer and Partner portal. Add information or communicate about the cases directly with the support team.
