Version 2.1 | Published October 06, 2017 ©
Network Requirements
A Viz Engine can be shared by multiple simultaneous NLE clients; however, there are no recommended number of users for SD and HD as this in most cases is a performance issue and not a fixed limitation.
The Windows- and Mac-based NLE system setup typically operate on a single Viz Engine. This requires transportation of frames (images) over the network, so a fast network connection is recommended, preferably a gigabit switched network connection; however, a megabit (100 Mbit/s) connection will also work as the plugin supports lossless data compression using Portable Network Graphics (PNG) or Run-length Encoding (RLE) instead of uncompressed raw images.
Note:
RLE is only supported by Viz Engine 3.2.2, or later.
Port Numbers
The table below describes all listeners, port numbers, and which applications that use the port numbers to establish a connection.
Port numbers
Listener
Port
Description
Viz Engine
6100
Default port used for graphics rendering.
Viz Trio
6210
Used by the Graphics Plugin to establish a connection to Viz Trio.
Viz Pilot
6220
Used by the Graphics Plugin to establish a connection to Viz Pilot.
Graphics Plugin Editor
6230
Used by the Graphics Plugin to establish a connection to the Graphics Plugin Editor.
Viz Pilot Edge
6230
Used by the Graphics Plugin to establish a connection to Viz Pilot Edge.
Graphics Plugin Config
6240
Used by the Graphics Plugin to establish a connection to the Graphics Plugin configuration tool.
Media Sequencer
8594
Port used by all clients that connect to the Media Sequencer.
Viz Engine
14300
Alternative port used to avoid conflicts with port 6100. Port 6100 is normally used by renderers that are on air, hence, it is (for example when running Viz Pilot version 4) recommended to use another port.
Viz Engine (multiplexed)
50007
50008
50009
Used by clients that connect to a multiplexed Viz Engine.
50007: Isolated port. All connections to this port get its own session. The port is used by the Graphics Plugin to deliver frames to the host NLE system. For example rendering or scrubbing of video clips with graphics. Using this port will also suppress bounding box commands. Cannot be used by Viz Pilot.
50008: Shared port. All connections from one single host share one session. Used by Viz Trio and Viz Pilot to display preview frames.
50009: Fixed port. Same as shared port, except that allocated resources are never cleared from memory. Used by Viz Pilot 4.
Connection Broker
21098
Connection to the Connection Broker configuration interface (for examplehttp://localhost:21098/).
