Version 2.1 | Published October 06, 2017 ©
Lift and Extract
When using Viz Pilot as your Editor, Lift and Extract allow you to remove a portion of a clip from the timeline. This is usually set by the mark-in and mark-out points.
  • Lift will remove a portion of a clip, while leaving the interval duration between the mark-in and mark-out points.
  • Extract will remove a portion of a clip, but does not leave the interval (cutting the portion of the clip out completely)
Although Lift and Extract modify the clip, no frames in the graphic are skipped. The portions of the clip before mark-in and after mark-out are separate entirely, and the graphic will also be split.
