Viz Engine
DVE Performance with X.mio3, X.mio2 Plus and X.mio2 Systems
This section details the available DVE inputs that can be used simultaneously on systems with the Matrox X.mio3, X.mio2 Plus or X,mio2 video boards.
X.mio2 video board exclusively: Installation of the Matrox X.RIO expansion module provides the Matrox X.mio2 video card with four more inputs, allowing for up to 8 video inputs on the X.mio2.
The values detailed in the following tables should be considered as reference, as the actual performance can differ slightly depending on the performance of the system in use.
PAL/NTSC
Scaling [%]
Foreground/Background
X.mio3SDI-Inputs
X.mio2 PlusSDI-Inputs
X.mio2 with X.RIOSDI-Input
100
On
8
8
8
Off
8
8
8
99
On
8
8
8
Off
8
8
8
50
On
8
8
8
Off
8
8
8
720p50
Scaling [%]
X.mio 3SDI-Inputs
X.mio2 Plus SDI-Inputs
X.mio2 with X.RIOSDI-Inputs
100
On
8
4
4
Off
8
5
5
99
On
8
3
3
Off
8
4
4
50
On
8
6
6
Off
8
6
6
720p60M
Scaling [%]
X.mio3SDI-Inputs
100
On
8
3
3
Off
8
4
4
99
On
8
2
2
Off
8
3
3
50
On
8
5
5
Off
8
5
5
1080i50
Scaling [%]
X.mio3SDI-Inputs
100
On
8
4
4
Off
8
5
5
99
On
8
3
3
Off
8
4
4
50
On
8
5
5
Off
8
5
5
1080i60M
Scaling [%]
X.mio3SDI-Inputs
100
On
7
3
3
Off
8
4
4
99
On
7
2
2
Off
8
2
2
50
On
8
2
2
Off
8
2
2
Note: For setups using the Matrox X.mio2 without the X.RIO expansion module, 4 is the maximum number of inputs. Consequently, for resolution and scaling combinations where the maximum supported inputs are less than 4, the X.RIO module is not required.
