Viz Engine
Special Configuration Options for Bluefish444
This section describes the procedures to configure the following options when running a Bluefish444 setup:
To Enable Dual Link Input for Epoch | 4K Supernova and Epoch | 4K Supernova S+ Boards
Stop Viz Engine.
Open the Viz Configuration file (for example: VIZ-<hostname>-0-0.cfg)
Note: The default location for this file is %ProgramData%\Vizrt\Viz3
Locate SECTION VIDEO.
Enable the Dual Link Input setting by changing the default value 0 to 1:
dual_link_input =
1
Save the file
Start Viz Engine
To Enable Dual Link Output for Epoch | Neutron
Stop Viz Engine.
Enable the Dual Link Output setting by changing the default value 0 to 1:
dual_link_output =
1
Save the file
Start Viz Engine
To Enable Automatic Bypass for BlueFish444 Epoch Boards
Viz Engine supports automatic mechanical bypass (copper-to-copper) of video for BlueFish444 Epoch boards. To use this feature enable the feature.
Stop Viz Engine.
Enable the Watchdog setting by changing the default value 0 to 1:
video_use_watchdog =
1
Save the file
Start Viz Engine
