Control 3D Stereoscopic Clip Playback
To playback 3D Stereo Clips, Viz Engine must be started with the -3D parameter. This sets Viz Engine in a mode where a side by side clip will be split and played out on channel A and B on the Matrox board.
Note: This is for clips only.
The playback on each output channel can be controlled with several shared memory variables. Each channel has its own set of variables indicated by the A and B in the names. The meaning of each of them is the same for both output channels.
HScale / VScale: Scales the output image relative to the image anchor (see XAnchor and YAnchor) in the respective direction.
HSort / VSoft: Applies softness to the scaled region of the source image only, and is defined as the percentage of pixels to be softened from the border to the center.
XTrans / YTrans: Translates the output image in the respective direction.
XAnchor / YAnchor: Defines the position of the anchor on the input image. The axis center equals the center of the input image.
Sharpness: Sets the amount of additional sharpness to apply to the output image.
To control the behavior of clip playback, the following shared memory variables exist:
vizrt.com.StereoClip.changed vizrt.com.StereoClip.A.HScale vizrt.com.StereoClip.A.VScale vizrt.com.StereoClip.A.HSoft vizrt.com.StereoClip.A.VSoft vizrt.com.StereoClip.A.XTrans vizrt.com.StereoClip.A.YTrans vizrt.com.StereoClip.A.XAnchor vizrt.com.StereoClip.A.YAnchor vizrt.com.StereoClip.A.Sharp vizrt.com.StereoClip.B.HScale vizrt.com.StereoClip.B.VScale vizrt.com.StereoClip.B.HSoft vizrt.com.StereoClip.B.VSoft vizrt.com.StereoClip.B.XTrans vizrt.com.StereoClip.B.YTrans vizrt.com.StereoClip.B.XAnchor vizrt.com.StereoClip.B.YAnchor vizrt.com.StereoClip.B.SharpSee Also
For more information about setting stereo modes, see the Camera page in the Configuring Viz section of the Viz Engine Administrator Guide.
Calculate the Days of a Week and Month script example
