Import Files
Use File Import to import these items:
Fonts
Images
Geometries
Scenes
Audio clips
Path Alias
Use a path alias to help streamline the import process. Path Aliases, defined in Viz Configuration, create shortcuts to frequently used file paths for import operations.
Browse for Files to Import
Use the import file list, on the left side of the Import Window, to browse the directories on a disk:
Double-click a directory to show its sub directories
Click a directory to show the contents in the right window
Click a path alias to quickly jump to this directory
Hold down the <Ctrl> key and click all required files to select multiple files.
To Import Selected Files
Select the target folder in the Server panel.
Click Import.
Select the type of file to import:
Click the Import Menu and select the type of file to import, or press the keyboard shortcut.
In the Import directory tree, search for the files to import.
Select the required file or files.
Images only: Select the import compression for the image or images. Click on Import Compression. Options are:
None
Select automatically: If the source image has an alpha channel, DXT5 will be used. If the source image does not have an alpha channel, DXT1 will be used.
DXT1: Works best on images without an alpha channel.
DXT5: Works best on images with an alpha channel.
Import the selected file or files:
Drag the file or files to the target folder, in the Server Panel (1), or
Double-click a single file (the file is added to the target folder)
If a reference to a file, which is to be imported, already exists in the Graphic Hub, this dialog will show:
Select from:
: Overwrite the file in Viz Artist -
: Rename the file and import (new file). Opens a new dialog, type and new name and press OK -
: Stop the file import of the file shown in dialog window. The import procedure continues with the next file -
: If there are multiple files, overwrite all files -
: Stop the import of all files
Adobe After Effects projects only: If image or clip files already exist in Viz Artist, import and overwrite them (Active) or do not import files which already exist (Inactive).
Tip: If there are no changes in the image or clips files, select Inactive. The import will be much faster, because no output from the Adobe After Effects Renderer is required.
Shape layer in After Effects can be imported to the scene as 2 types of objects, video and geometry plugins, depends on its complexities
Rectangle created by Rectangle or Rounded Rectangle tools will be imported as Noggi object
Ellipse created by Ellipse tool will be imported as Eclipse object
Star and Polygon will be imported as Star object if
Inner and Outer roundness is 0 and
Star point is integer number
Shape created by Pen tool will be imported into Polygon object
Converted shape from text, each character of it will contains multiple paths.
Shape of each character merge all paths in a special mode (be decided by After Effects among Add, Subtract, Intersect and Exclude Intersections depends on the overlapping and direction of each path) that we not support it even most of character works with our simple merging method, "Exclude Intersections", manually change Merge Paths mode of all characters to "Exclude Intersections" can make this layer be import into Polygon object instead of video.-
Use Horizontal or Vertical Type Tool to create a text layer
Right click on the text layer and select "Create Shapes from Text"
Expand "Merge Path" and change Mode to "Exclude Intersections"
Convert shape from imported external vector graphic file such as .eps. This is similar to the converted text but it might have many groups of paths
To import .eps file to After Effects and make it be able to imported as as Polygon object in Viz Artist-
Press CTRL+I and select a vector files
Right click on the vector layer of automatically created composition and select "Create Shapes from Vector Layer"
Expand Contents and every groups inside, each group is the same as character of converted text
Some converted vector shape have multiple group of merged paths and not work with "Exclude Intersections" merging and mostly one group with single path is used as boundary.
In this case that group (Merge Paths and its above Path) can be deleted and other groups can use "Exclude Intersections" creates correct result
We support layer animation but not object animation inside, the layer will be imported as video if any properties of them have a key-frame.
