Viz Plug-ins User Guide
Line Stack
images/download/thumbnails/114312739/ico_lstack.png
Create a stacked chart consisting of several Line Charts.
Note: This plug-in is located in: Plugins -> Container plug-ins -> VisualDataTools
Line Stack Properties
  • Initialize stacked chart: Refreshes the stacked chart, based on the Line Chart plug-ins in the sub-containers. The stacked chart detects when a chart is added/removed from the stack, and updates the chart accordingly. However, some actions, such as re-ordering the charts within a stack, are not updated automatically. In these cases, press Initialize stacked chart to update the stack.
  • Stack Gap: Adds space between each chart.
Note: The remaining properties in the Line Stack plug-in are the same as used in the Line Chart plug-in. The Line Chart features Specify X Values, DataY Compare, and Bevel, are disabled in stacked charts.
To Create a Scene with Line Stack
images/download/thumbnails/114312739/pc_lstack_st.png images/download/attachments/114312739/pc_lstack_pv.png
  1. Create a new container.
  2. Add a Line Stack plug-in into this container.
  3. Add two or more Line Chart plug-ins to become children of this container.
  4. Add Data Y into each chart. They should have the same number of nodes.
  5. In the settings of the Line Stack plug-in, press Initialize Stacked Chart to refresh the chart.
  6. Use the Line Stack plug-in to set the chart parameters that are common for all charts in the stack.
