Viz Plug-ins User Guide
viz_sealevel
The viz_sealevel plug-in allows Viz Engine to provide GPIO data coming from SeaLevel Devices for plug-ins and scripts.
Both SeaLevel PCI and ethernet Devices are supported. The GPIO data is provided in via SHM key/values and via message passing.
SHM Interface
Each GPIO pin is mapped to a SHM key.
Format
The pins are mapped with following format:
  • Inputs: Sealevel::<device-id>::I<pin-id>::<0 or 1>
  • Outputs: Sealevel::<device-id>::O<pin-id>::<0 or 1>
SMM Values in Viz Engine REST Interface
images/download/attachments/158761064/smm_view.png
Inputs
These SHM values are only for reading and are updated when a input pin changes. By registering to SHM changes this can then be used to perform tasks in scripting or plug-ins.
Outputs
These values are meant to set from inside scripts or plug-ins (for example to switch lights on and off).
Message Interface
The Viz Engine plug-in API supports communication via message passing which is similar to a REST API. Messages can be send via Request(location, message) in Viz Script.
List Devices
Response:
"id": "1",
"name": "410io_",
"status": "connected",
"status-description": "Connected"
Get Device Info
Response:
"id": "1",
"name": "410io_",
"status-description": "Connected",
"pins": [
"id": "0",
"is-input": true,
"value": 0
"id": "1",
"is-input": true,
"value": 0
"id": "2",
"is-input": true,
"value": 0
"id": "3",
"is-input": true,
"value": 0
Register for Pin Changes
Response:
"error": false
If then a pin changes the script or plug-in would receive such a response:
Response:
"device": 1,
"pin": 1,
"value": true
Get All Pin Data for a Given Device
Response:
"id": "0",
"is-input": true,
"value": 0
"id": "1",
"is-input": true,
"value": 0
"id": "2",
"is-input": true,
"value": 0
Get Pin Data for a Given Device and Pin
Response:
"id": "0",
"is-input": true,
"value": 0
Set Pin Data for a Given Device and Pin
Message:
"value": 1
Response:
"id": "0",
"is-input": true,
"value": 1
Configuration
To Configure this plugin create a file called {VizEngine-Config-dir}/extensions/Sealevel.json. This file is used for every running instance of Viz Engine. To have a specific config for a running instance you can create config files like {VizEngine-Config-dir}/extensions/Sealevel-{Instance-Number}.json.
Supported config parameters:
  • auto-reconnect: Automatically reconnect to device.
  • reconnect-interval: Interval for reconnecting.
  • discover-ethernet-devices: Automatically detect SeaLevel network devices.
  • ethernet-devices: Array of SeaMax devices connected via Ethernet.
    • address: IP address.
    • name: Assocciated name for this Card.
  • seaio-devices: Array of SeaIO device (PCI-Cards).
    • adapter: Adapter number for PCI-Card (For two installed PCI-Cards possible adapters would be 0 and 1).
  • serial-devices: Array of SeaMax devices connected via serial interface.
    • port: COM port for this device.
The Sealevel.json file would then look like this:
"auto-reconnect": true,
"discover-ethernet-devices": true
"ethernet-devices": [
"port": "COM1",
"name": "serial_card_0"
"reconnect-interval": 60000,
"seaio-devices": [
"adapter": 0,
"name": "pci_card_0"
"serial-devices": [
"port": "COM1",
Sample Scripts
List Devices
sub getDevices()
Request("/Extensions/Sealevel/devices", "")
end sub
sub onDevices(devices as Json)
if devices.Size == 0 Then
exit sub
end if
dim devCount as Integer = devices.Size - 1
for i = 0 to devCount
dim deviceObj as Json = devices.At(i)
Println(deviceObj.Dump())
Next
end sub
sub OnResponse(location as string, message as string)
if location == "/Extensions/Sealevel/devices" Then
dim j as Json
j.Load(message)
onDevices(j)
end if
end sub
getDevices()
Get Pin Values
sub getPinValue(devId as String, pinId as String)
Request("/Extensions/Sealevel/devices/" & devId & "/pins/" & pinId, "")
end sub
dim j as Json
j.Load(message)
onPinValue(j.GetString("id"), j.GetInteger("value"))
end sub
sub onPinValue(pinId as String, value as Integer)
Println("Pin " & pinId & " value = " & value)
end sub
' Inputs
for i = 0 to 15
getPinValue("0", "" & i)
next
' Outputs
for i = 16 to 31
next
Set Output Pins
end sub
sub setPinValue(devId as String, pinId as String, value as Integer)
dim payload as String = "{\"value\": " & value & "}"
Request("/Extensions/Sealevel/devices/" & devId & "/pins/" & pinId, payload)
end sub
dim j as Json
j.Load(message)
end sub
end sub
setPinValue("0", "16", 1)
setPinValue("0", "18", 1)
' Outputs
for i = 16 to 31
next
Listen for Pin Changes
if location.StartsWith("/Extensions/Sealevel/devices") and location.EndsWith("change") Then
dim j as Json
j.load(message)
onPinChanged(j.GetInteger("pin"), j.GetInteger("value"))
end if
end sub
sub onPinChanged(pinId as Integer, value as Integer)
Println("Pin " & pinId & " changed to " & value)
end sub
Request("/Extensions/Sealevel/devices/0/register", "")
