Viz Plug-ins User Guide
MultiTouch Plug-ins
The MultiTouch plug-ins are used to take incoming touch events, process them and then trigger events, perform transformations on objects, telestrate, or trigger script events. The idea behind these plug-ins is to bundle often used or needed functionality and eliminate the need to write your own scripts or plug-ins for that. They are great tools to bring MultiTouch interactively fast and easily into a Scene. The Container plug-ins require the MtSensor to be available to work. If a MultiTouch plug-in is added to a Scene it automatically adds the MtSensor to the Scene if it is not there.
The MultiTouch plug-ins can communicate with Viz scripts, either through event handlers, Shared Memory variables, or Data Pool variables. The plug-ins can also be controlled by triggering the ‘push buttons’ and/or setting the ‘parameter’ variables exposed by the plug-in. Specifics on what features are available for each plug-in are documented in the plug-in specific sections below.
In the Viz Artist editor interface, the
button toggles between enabling and disabling emulated sensor input using the mouse as well as direct input from a sensor. The plug-ins work with multiple layers. Each Scene layer with MultiTouch objects installed in it should also have an instance of the MtSensor automatically installed.
The following Container plug-ins are located in the MultiTouchComp folder:
Make sure you also read up on the Plug-in Event and Notification System.
