Viz Plug-ins User Guide
Wave
images/download/thumbnails/125442156/ico_wave.png
The Wave plug-in allows you to create a wave sequence on a flat surface. The properties of the sequence are visualized in a graphical display in the wave editor.
Wave Properties
  • Size X and Y: Sets the size of the rectangle where the waves show.
  • Tesselation: The amount of triangles used to create the geometry. As higher as more calculations need to be performed
  • Geom Type: Allows you to select between Circular and Linear waves.
  • Stretch: Allows you to customize the form of the circular waves. By altering the stretch X and Y values, you can for instance obtain an oval or a compressed form of the waves.
  • Angle: Sets the angle of the waves when a linear mode is chosen.
  • Reference Point : Sets the position of the waves starting point.
  • Offset: Sets an offset value of the Ref.Pnt.
  • Damping Mode: Enables damping of the waves. The amplitude of the wave is reduced by the damp length calculated from the center of the wave.
  • Damping Length: Sets the length the distance that is used to damp the waves in the Damp. mode function.
  • Wavelength: Sets the length of the waves.
  • Amplitude: Amplifies the waves, resulting in both bigger and higher waves.
  • Time: Is the time-line for a wave sequence. You see a thin red vertical line moving in the graphical display as you alter the time value. You can also alter the value by dragging the red line.
  • Invert OFF/ON: Inverts the wave curves.
  • Position X and Y: Allows you to edit the position values of the wave control points. Select a point by clicking on it. Its color changes to red to show that it is selected. Now you can drag it around.
  • Envelope Generator: Draws the wave manually when enabled. When disabled the wave is built by a sine wave function.
  • Mirror: Allows you to decide whether the points controlling the crest of the waves should be edited in a locked manner, with the points controlling the troughs of the waves or conversely, if they are to be edited separately.
To Create a Wave
images/download/attachments/125442156/image2022-12-6_10-29-31.png
  1. Create a new group and add the Wave plug-in to it.
  2. Open the Transformation Editor and set Rotation X to -75.0.
  3. Add a material and/or a texture to it.
  4. Open the Wave editor and set the following parameters:
    • Set Size X and Y to 350.0.
    • Set W.-Length to 8.0.
  5. Click the Lock button to unlock the spline curve editor.
  6. Play with the spline curve handles, Time, Position X and Y values to see how the wave behaves with different settings.
