Viz Plug-ins User Guide
Map Builder
images/download/thumbnails/57216911/mapsb_ico.png
The Map Builder plug-in builds a scene from a map template (*.mtpl) file, and saves the map scene changes to the map template file.
Note: This plug-in is located in: Plugins -> Scene plug-ins -> Maps
Map Builder Properties
  • Map Template Filename: Sets the name of the scene template file or click the browse (...) button to select a file.
  • Rebuild Scene: Updates the scene tree with changes from the Map Builder.
  • Launch Wizard: Runs the Map Builder application.
  • Clean Scene: Cleans the scene hierarchy.
  • Build Scene from Scratch: Cleans the scene tree and rebuilds the scene hierarchy using the defined map template file.
