Viz Plug-ins User Guide
Wall
images/download/thumbnails/114311987/wall_ico.png
The Wall plug-in creates a curved wall object. The size and curving of the wall can be customized.
Wall Properties
  • Use LOD: Enables/disables dynamic level of detail.
  • Height: Sets the height of the wall.
  • Width: Sets the width of the wall.
  • Depth: Sets the depth of the wall curving. The higher this value is set, the more curved the wall is.
  • Angle: Sets the angle of the walls curving. Use this parameter together with Depth to achieve the desired curving of the wall.
  • Corners: Sets the number of internal corners the wall should be built up from.
  • Center: Sets the center axis of the object. Choose between Center, Bottom or Top.
  • Front: Lets you switch between front and back.
To Create a Wall
images/download/attachments/114311987/bipwall_example.png
  1. Create a new group and add the Wall plug-in to it.
  2. Open the Wall editor and set the following parameters:
    • Set Height to 200.0.
    • Set Width to 400.0.
    • Set Depth to 400.0.
    • Set Center to Center.
  3. Add a material and/or a texture to it.
  4. Open the Transformation Editor and set Rotation Y to -45.0.
