Viz Plug-ins User Guide
Spline Path
images/download/thumbnails/114312008/ico_spath.png
The Spline Path plug-in creates complex paths with an arrow look.
Spline Path Properties
  • use LOD: Enables/disables dynamic level of detail.
  • Node: Defines the node index. For example, node 3 or node 25.
  • X, Y and Z: Sets the 3D point to define a node.
  • Length: Stretches the entire path in X-direction.
  • Width: Stretches the entire path in Y-direction.
  • Threshold: Increase this value if you do not need a high path accuracy but more performance.
  • Add, Move, Remove and Clear: Add adds a new node with an specific index. Move moves an existing node to another X, Y or Z-point. Remove removes an existing node. Clear clears all nodes.
  • Mode: The following options are available:
    • Tube: Renders the entire object.
    • Band XY: Renders only the front side.
    • Band XZ: Renders only the top side.
    • Band YZ: Renders only the left side.
  • Arrow: Creates an array look.
  • Arrow Length: Sets the arrow length (only when Arrow is set to On).
  • Arrow Width: Sets the arrow width (only when Arrow is set to On).
  • Texture Stretching Mode:
To Create a Spline Path
images/download/attachments/114312008/pc_spath_x.png
  1. Create a new group container.
  2. Add the Spline Path plug-in.
  3. Add the Expert plug-in.
  4. Open the Expert editor.
  5. Set Back Face to On.
  6. Add a Material and/or a Texture to the group.
  7. Open the Spline Path editor.
  8. Set Node to 0 / X to 50.0 / Y to 50.0.
  9. Click Add.
  10. Set Node to 1 / X to 150.0 / Y to 25.0.
  11. Click Add.
  12. Set Node to 2 / X to 250.0 / Y to 10.0.
  13. Click Add.
  14. Set Node to 3, X to 350.0, Y to 45.0.
  15. Click Add.
