Version 5.0 | Published November 09, 2022 ©
Audio
Viz Mosart connects to a variety of audio devices, from various manufacturers.
Select the required audio device from AV Automation > Devices > Preferences > Audio.
Audio Mixer
This tab enables setting-up of the main mixer and optionally, a backup.
images/download/attachments/95396189/audioMixer.png
  • Use Audio mixer: Enables the audio mixer functionality.
Audio Mixer Types
Audio mixer
Protocol
Supported hardware
Interface
CALCREC
RAP
RS-422, TCP/IP (Artemis)
DHD
DHD RM4200-D v2.02
TCP/IP
EUPHONIX
RAP
COM
LAWO RMNOPL
RemoteMNOPL
Lawo mc²
TCP/IP
LAWO ZIRKON
RAS, Lawo Zirkon subset
RS-422 or TCP/IP
LAWO EMBER+
Ember+
TCP/IP
MIDIMIXER
Sanford.Multimedia
MIDI
SSL
Light Broadcast Automation protocol, SSL Broadcast Automation Control Specification – v1.0
RS-422 or TCP/IP
STAGETEC
Stagetec Diamond RAS protocol, Monitora RAS
COM
STUDER_3000
Monitora + Ember, Ember 1.0
Studer OnAir 3000
RS-232 or TCP/IP
STUDER_VISTA
Ember
Studer Vista
TCP/IP
VIZENGINE
n/a
Viz Opus only
TCP/IP
WHEATSTONE
Wheatstone Mixer Automation Protocol v.1.4
TCP/IP
YAMAHA_O2
MIDI
Yamaha 01V96, DM1000, DM2000, DME64N, O2V96, LS9, CL5
MIDI
vizrt-ips
NewTek
Vizrt Group/NewTek IPseries mixers. TriCaster, VMC, Viz Verdi, Viz Vectar
TCP/IP
  • Serial (Calrec, Lawo, Studer, etc.): Serial port connected to the audio mixer, when Serial radio button is selected.
  • TCP/IP: Hostname or IP address and port to communicate with the audio mixer, when TCP/IP radio button is selected. Note that for Calrec it is possible to configure a main and backup audio mixer by specifying two comma separated hostname values and port values.
  • Backup hostname and port (LAWO RMNOPL): Hostname (or IP address) and port to the backup audio mixer console.
  • Set user labels on console: When selected, user labels on the Lawo or Vista console are overwritten.
  • MidiCh (MIDIMIXER and YAMAHA_O2): MIDI channel assigned to the audio mixer.
  • Midi Input port (MIDIMIXER and YAMAHA_O2): System MIDI input port to communicate with the audio mixer.
  • Midi Output port (MIDIMIXER and YAMAHA_O2): System MIDI output port to communicate with the audio mixer.
  • Default fade time: Time in frames for fading open faders with the manual fade function (CTRL+F).
  • Default snapshot: Snapshot to recall when starting the automation (MIDI parameter change).
  • Audio effect server: Name for the Audio effect fader. This fader will open if effect transitions are used.
  • Send reset command on connect: Used for STUDER3000 SW 2.2, or lower. Recalls a default setup for the Mixer panel.
  • Visible audio faders: Maximum visible faders in AV Automation.
AV Automation Audio Mixer Availability Table
Serial
TCP/IP
MidiCh
Midiport
Hostname
Port
Backup
host name
Backup
Port
Faderinput
offset
Useember
protocol
Comport
audiomixer
CALREC
x
x
x
x
x
DHD
x
x
x
EUPHONIX
x
x
LAWO
RMNOPL
x
x
x
x
x
LAWO
ZIRKON
x
x
x
x
x
LAWO EMBER+
x
x
MIDI
MIXER
x
x
SSL
x
x
x
STAGETEC
x
x
x
x
x
STUDER
3000
x
x
x
x
x
x
STUDER
VISTA
x
x
x
VIZ
ENGINE
x
x
x
WHEAT
STONE
x
x
x
YAMAHA
O2
x
x
Vizrt
ips
x
x
x
Audio Player
A basic audio player is always included as standard in a Viz Mosart.
images/download/thumbnails/95396189/audopPlayer.png
Requirements
Refer to general section Prerequisites (section Viz Mosart Audio Player).
Setting Up an Audio Player
Refer to section Audio Players.
Operating an Audio Player
Refer to section Playing Audio in the Viz Mosart User guide.
Loudness Control
A loudness control from Junger.
images/download/attachments/95396189/configuration_avauto-loudness.png
  • Use loudness controller: Check the box to enable loudness control.
  • Loudness controller type: JUNGER T*AP.
  • Triggers/levels: Name of triggers or loudness levels, one for each line. These will appear in a tool-tip menu in the Template editor, and must correspond to the configuration in the loudness controller(s).
  • Channels: Fixed values. For Junger T*AP there are four stereo channels per host. Connections to the audio faders are configured in A/V Setup/Edit/Audio config/Loudness channel.
  • Host:port: Hostname or IP address and optional port number for each controller.
Note: If the root node name is different than T*AP the name must be set in the AVA configuration property JungerRoot .
