Version 5.0 | Published November 09, 2022 ©
sq_sequence
The sq_sequence table contains recorded sequences from a Viz Mosart Automation. Sequences are gallery dependent and related to the template set in use when recorded. A sequence makes it possible to record any sequence from a rundown in Viz Mosart automation for later playback.
Name
Type
Allow Null
Description
sq_recno
integer
No
Primary key.
sq_ga_recno
integer
No
Foreign key referencing the corresponding gallery ga_recno in the ga_gallery table.
sq_ts_recno
integer
No
Foreign key referencing the corresponding template set ts_recno in the ts_templateset table.
sq_name
varchar(32)
No
Name of sequence.
sq_description
varchar(128)
Yes
Optional description of the sequence.
sq_xml
longtext
No
The gallery specific implementation of the sequence. Stored as received from Mosart Automation in XML.
