Version 5.0 | Published November 09, 2022 ©
fi_field
The table fi_field contains valid fields or newsroomtags used by Mosart templates for receiving user input. Normally these fields are exposed to the uses in the NRCS via dedicated ActiveX components. Note that a single field can be shared by many templates.
Name
Type
Allow Null
Description
fi_recno
integer
No
Primary key.
fi_name
varchar(32)
No
The field name. Normally presented to users.
fi_description
varchar(128)
Yes
Optional field description.
fi_type
varchar(32)
No
The field type. Supported values are ‘ENUMERATION’, ‘NUMBER’, ‘STRING’.
fi_en_recno
integer
Yes
Optional foreign key for ENUMERATION fields.
If set, referencing the corresponding enumeration in the en_enumeration table.
fi_mask
varchar(128)
Yes
Optional input mask. Used for STRING fields only.
