This is the administrator documentation for Vizrt Asset Management (VAM): installing it, operating it, and using the Configuration Service that ships with it.
For problems, contact Vizrt support, see Getting Help. To get VAM licenses, contact your Vizrt representative.
Start with the section that matches the task in front of you. Each section stands on its own, so there is no need to read them in order.
Sections
Installer
End-to-end guide for installing VAM on a Windows host using the vamctl installer.
  1. Installer Overview
  2. Prerequisites
  3. Identity Provider Setup
  4. Running the Installer
  5. Post-Install Validation
  6. Upgrading
  7. Uninstalling
  8. Troubleshooting the Installer
  9. VMware vSphere Deployment
  10. Offline (Air-Gapped) Installation
  11. Existing Kubernetes Cluster
Operator guide for the Configuration Service, the in-cluster web UI used to manage packages, platform settings, certificates, backups and cluster health after installation.
  1. Configuration Service Overview
  2. Signing In
  3. Managing Packages
  4. Platform Settings
  5. Backup and Restore
  6. Cluster and Health
  7. Troubleshooting the Configuration Service
Conventions
  • The Glossary explains the terms used in this guide.
  • Screenshots are taken from the latest released installer and configuration UI. If a screen in your installation looks different, check that you are on the matching VAM version. The Packages view of the Configuration Service shows it on the Vizrt Asset Management card.
  • Code-style boxes show literal text: file paths, command lines, or values you type into a UI field.
  • Where a step requires elevated privileges or affects a running production cluster, it is marked with a warning callout.
Getting Help
When you open a support case with Vizrt support, include:
