Version 1.5 | Published April 05, 2022 ©
Viz Virtual Studio Installation
There are several setup applications available to install the components of Viz Virtual Studio, as indicated in the table below:
Setup Application
Content
VizVirtualStudioBundle-x64-<VERSION>.exe
Bundle with Tracking Hub and Studio Manager
StudioManager-x64-<VERSION>.msi
Studio Manager installer
TrackingHub-x64-<VERSION>.msi
Tracking Hub installer
It is recommended to install Studio Manager and/or Tracking Hub using the Tracking Hub Bundle setup application, as this installs most of the prerequisite software as well.
Prerequisites for Tracking Hub are:
  • Microsoft Visual Studio C++ 2012 Runtime
  • Sentinel Runtime/WIBU Codemeter Runtimes
Prerequisites for Studio Manager are:
  • Microsoft .Net 4.5.1 or higher.
Studio Manager asks to download Microsoft .Net 4.5.1 on startup if it is not already installed.
To Install Tracking Hub and Studio Manager Using the Bundle Installer
  1. Log on to the computer as a Computer Administrator and start VizVirtualStudioBundle-x64-<VERSION>.exe to run the setup application.
  2. By default, the Tracking Hub and Studio Manager options are selected in the installer. If required, remove the options.
    images/download/attachments/85893601/VSBundleInstaller.JPG
  3. Click Install and follow the on-screen instructions.
    Note: The packages to install can be selected by check boxes, except the Microsoft Visual C++ 2012 Redistributable package, as it is a prerequisite. If a package is already installed (e.g. the Sentinel Runtime Dongle Driver), the check box is disabled.
After installation, the Programs and Features panel shows entries for each installed package
images/download/attachments/85893601/Installed_Applications.JPG
To Repair or Remove Tracking Hub
Once the Bundle has been installed, you can run the Tracking Hub Bundle setup application again to enter Repair or Uninstall modes. Select Repair or Uninstall as required:
  • Uninstalling the bundle removes each individual package. Exceptions are the Microsoft Visual C++ 2012 Redistributable and the Sentinel Runtime packages, as they are intended to remain on the PC. You can remove these packages separately, if desired.
  • After Repairing, you must restart the computer. After restarting, you can proceed to Start the Viz Virtual Studio.
Unattended Installation of Viz Virtual Studio Applications
Installation Parameters
Parameter name
Default Value
Available values
Tracking Hub MSI
INSTALLFOLDER
%\Program Files%\Vizrt\VizTH\
Studio Manager MSI
INSTALLFOLDER
%\Program Files%\Vizrt\StudioManager\
Virtual Studio Bundle
INSTALLFOLDER
Example
Description
Command
Install Tracking Hub in unattended mode with only progress bar using the msi installer and installation path is C:\TH
msiexec /i TrackingHub.msi /passive INSTALLFOLDER="C:\TH"
Install Studio Manager silently with no UI using the msi installer and installation path is C:\SM
msiexec /i StudioManager.msi /qn INSTALLFOLDER="C:\SM"
Install Tracking Hub in C:\TH and Studio Manager in C:\SM and all necessary MS Visual C++ redistributables, CodeMeter runtime kit and sentinel runtime using Virtual Studio Bundle
VizVirtualStudioBundle-x64.exe --silent --trackinghub=INSTALLFOLDER='C:\TH' --studiomanager=INSTALLFOLDER='C:\SM'
