Viz Multiplay User Guide
Version 3.0 | Published October 23, 2020 ©
Organizing Media Content
Browse Shows Window
Click the Open button on the Toolbar to open the Browse Shows Window.
images/download/attachments/61155915/image2019-9-4_14-41-46.png
Open or delete existing shows or create new shows. Rename a show by selecting it and pressing F2. Select a show to open it in the Show Pane.
Show Pane
images/download/attachments/61155915/image2019-9-4_14-42-41.png
The Show pane at the top left of the main window displays the playlists and groups that are part of your show and connected to a certain profile. The Page List contains the name of the show; the other tabs are playlists.
Locating Page Lists, Playlists and Groups
Each tab contains Groups (3), and each group contains the media elements for a story. Select a group to load related media elements into the Media Column.
images/download/attachments/61155915/image2019-9-4_14-45-6.png
Add, Delete or Rename a Group
Add a New Group to the Bottom of the List of Groups
  1. Click Add (+) at the bottom of the show pane:
    images/download/attachments/61155915/usingvmp_addnewgroup.png
  2. Give the group a name and press ENTER.
Insert a Group into a Specific Spot in the List of Groups
  1. Right-click a group and select Insert new group from the shortcut menu.
    IMPORTANT!
    Important! The new group will be inserted directly above the group you right-click.
    images/download/attachments/61155915/image2018-6-11_14-16-25.png
  2. Give the new group a name and press ENTER.
Delete a Group from the Show Pane
Right-click a group and select Delete from the shortcut menu, or
  1. Click the trash can icon at the bottom of the show pane.
    images/download/attachments/61155915/image2018-6-11_14-17-34.png
  2. Click Yes when prompted.
Rename a Group
  1. Double-click a group.
  2. Enter a new name.
  3. Press ENTER.
    Tip: Groups can also be created and modified in Viz Trio.
Move Groups to Other Playlists in the Show Pane
Move a group by dragging, with a copy/paste operation using standard Windows keyboard shortcuts or via a group’s shortcut menu.
Workflow Examples
Drag a group to another playlist tab:
images/download/attachments/61155915/usingvmp_playdrag.png
You can also move a group using CTRL + C and CTRL + V or the shortcut menu:
images/download/attachments/61155915/image2019-8-28_11-33-7.png
Add a New Playlist
  1. Click Add (+) to create a new playlist or open an existing external playlist.
    images/download/attachments/61155915/usingvmp_addplay.png
    1. Create new playlist: The playlist will be owned by the show and appear as a tab in the Show pane but will not be visible in the show/playlist directory tree.
      images/download/attachments/61155915/usingvmp_playlist_add.png
    2. Add existing playlist: Open existing playlists from Viz Pilot or other newsroom systems.
      images/download/attachments/61155915/usingvmp_playlist_add_exist.png
  2. Click X (Close) to delete an internal playlist or remove the reference to an external playlist.
  3. Click Ok.
    Tip: Playlists can also be created and modified in Viz Trio.
Working with Playlists
Rename a Playlist
  1. Double-click the playlist title.
    images/download/attachments/61155915/usingvmp_dclick.png
  2. The title field becomes editable.
    images/download/thumbnails/61155915/usingvmp_edit.png
  3. Enter a new title in the field and press ENTER to confirm.
    images/download/thumbnails/61155915/usingvmp_newtitle.png
Re-position a Playlist
  1. Click and drag the playlist to the desired position in the top menu.
    images/download/thumbnails/61155915/usingvmp_click.png
    images/download/thumbnails/61155915/usingvmp_dragplay.png
