Viz Multiplay User Guide
Version 3.0 | Published October 23, 2020 ©
System Overview
images/download/attachments/58339981/vizmultiplay_standard_system_mse11.png
Viz Multiplay
  • Is compatible with graphics from Viz Trio and Viz Template Wizard. Shows from Viz Trio are available in Viz Multiplay.
  • Can access and use templates and elements in a Pilot Data Server.
  • Is hosted on a URL on the Media Sequencer. Any number of clients can connect to the same Media Sequencer, which provides the scheduling for playout.
  • Uses Viz Engines for playout:
    • The video wall feature allows up to four DisplayPort outputs with UHD resolution from a single GPU in a Viz Engine. With Datapath Fx4 display controllers, the number of outputs can be increased to match numerous screens and panels of different shapes and orientations.
    • Also supports Standard SDI-based playout.
  • Can access media assets stored in Viz One and Media Service.
  • Can open MOS playlists.
Note: It's recommended to check the performance of scenes when using complex configurations.
