Viz Multiplay User Guide
Version 3.0 | Published October 23, 2020 ©
The Sources Pane
Use the Sources Pane to find media for your show:
  • Media Tab: Search for assets in specified search providers.
  • Inbox Tab: Content that is always available, across all shows.
  • GFX Tab: Graphical elements to be used in your show.
  • Video Walls Tab: Presets for Superchannel-based video walls.
  • Dynamic Walls Tab: Presets for DynamicChannels based video walls.
  • Templates Tab: Viz Pilot templates and elements.
Note: The Show/Hide button on the Toolbar allows you to Hide Sources Pane and Show pane.
Media Tab
images/download/attachments/58340564/image2019-1-2_16-8-28.png
Note: Before using the Media Tab, make sure your search providers have been configured in Settings > Servers Tab.
In the Media tab, you can search for video and images in any of the search providers you have connected to, including Preview Server, Viz One, Pilot Data Server, Media Service and Graphic Hub.
Once the element is found, drag it from the Media Tab to your channels.
Add Items to Channels from the Media Tab
Drag individual items or groups of items into channels from the Media tab.
  1. Click the Media tab.
  2. Select a media type.
  3. Drag an item into a channel.
  4. Hold CTRL and click multiple items to drag them as a group into a channel.
Media Search Filters
Note: Not all search criteria are supported for all search providers; unsupported criteria are hidden if unavailable.
    • Keyword search: Searches descriptions
      images/download/thumbnails/58340564/image2017-11-3_13-43-4.png
    • Media type: Video or Image
      images/download/thumbnails/58340564/image2017-11-3_13-54-27.png
    • Date range: Filter by date. All items, Last hour, Last day, Last week, Last month. Works with media from Viz One, Media Service, Pilot Data Server.
      images/download/attachments/58340564/usingvmp_media_date.png
    • Tags: Works with media from Pilot Data Server and Viz One. Only one tag can be selected at a time.
      images/download/attachments/58340564/image2017-11-3_14-6-44.png
    • Search Provider: Select media sources for your search (Pilot Data Server, Media Service, Viz One, Graphic Hub and Graphic Hub: default folder).
      images/download/attachments/58340564/search.png
      Note: Graphic Hub REST service versions higher than 2.0.1 support Graphic Hub: default folder as a search provider, in addition to Graphic Hub. The default folder only contains images ingested through the Graphic Hub REST API, while the Graphic Hub search provider exposes the full content of the Graphic Hub.
      Note: Viz One items marked as Blocked in the MAM system appear in search results with a visual mark. They are not usable in Viz Multiplay until they are unblocked in Viz one.
    Video Preview
    To preview a video, right-click an item and select Preview.
    Videos can be edited once they have been added to channels, see Editing Videos.
    images/download/attachments/58340564/usingvmp_preview_video.png
    Inbox Tab
    images/download/attachments/58340564/image2018-6-18_11-15-13.png
    Users can work together to find and collect elements that can be easily added to a story. An inbox is global, meaning that it is available regardless of what show is currently open.
    • Mark a show as an inbox by selecting it in Settings > Inboxes Tab.
    Any content added to the show (eg. Crops) is immediately available in the Inbox tab. Elements can be dragged from the Inbox tab to a channel.
    Note: When an element is dragged from the inbox to a channel in a show, it's copied, not referenced; this creates two separate elements that can be modified independently of each other.
    Note: There are several ways to ingest elements into an inbox dynamically - for instance through the Media Sequencer REST API.
    GFX Tab
    images/download/attachments/58340564/image2019-1-14_13-45-34.png
    The GFX tab is a playlist within the show populated by importing Viz Artist scenes directly from the Graphic Hub or by using Viz Trio or the REST API of the Media Sequencer. You can also drag or copy and paste elements from a channel into a group in the GFX tab.
    Note: The content from the GFX playlist is only available within the show in which the playlist is created. A playlist is set as the GFX tab by selecting it in Settings > General Tab> Graphics.
    The graphical elements can be empty templates or filled with content and can be edited once they have been added to a channel, see Editing Graphics. Any changes made inside an element are visible immediately.
    The Context Menu
    Right-clicking an element in the GFX tab open the menu, which includes the following option:
    • Reimport: Re-imports the graphics from the Graphic Hub. This is useful if the graphics designer has added or removed control fields.
    Changing Thumbnail Size and Aspect Ratio
    • Drag the slider right to view bigger thumbnails and left to view smaller thumbnails.
      images/download/attachments/58340564/image2018-6-18_11-21-31.png
    The thumbnails for each group in the GFX tab can have different aspect ratios. This is handy if you have wide scenes or portrait scenes meant for playout in GFX channels with the same aspect ratio.
    • Right-click a group in the GFX tab.
    • Select Set Aspect Ratio.
    • Choose an aspect ratio or select Custom.
    • In the custom box - enter a numeric value (width divided by height).
      images/download/attachments/58340564/image2019-1-14_13-2-58.png
    Video Walls Tab
    The Video Walls Tab contains the Superchannel based video walls imported from the profile.
    images/download/attachments/58340564/image2020-4-15_7-27-19.png
    Click the Plus button to import new walls or new sets of presets (preset scenes) for a video wall into the current show. One video wall can have multiple sets of presets imported into the show.
    If a set of presets has a yellow triangle next to it - it indicates that he presets has changed on the Graphic Hub - and they need to be reloaded. Right click and select Reimport to import the latest preset data from the Graphic Hub. Check for updates will check whether the presets on the Graphic Hub is updated since last import - for instance if a designer has modified the preset scene in Viz Artist.
    images/download/attachments/58340564/image2020-4-15_7-35-32.png
    Dynamic Walls Tab
    images/download/attachments/58340564/image2020-4-15_7-48-27.png
    The Videowall tab contains the video walls created with the DynamicChannels solution in Viz Multiplay. The tab displays a regular playlist within the show that contains a set of Presets (video wall layouts). The content from this playlist is only available within the show in which the playlist is created.
    • Set a playlist as the Videowall tab by selecting it in Settings > General Tab > Videowall.
    The presets can be empty video wall layouts, or can be filled with content (media and scenes). The elements can be edited once they have been added to a channel (see Editing Presets). Any changes made inside an element are visible immediately.
    Viewing Elements in the Videowall Tab
    • Drag the slider to adjust the size of presets:
      images/download/attachments/58340564/image2019-2-4_12-23-3.png
    Connect a Videowall Group to a Videowall
    Playout all the presets in a group on a specific videowall.
    Tip: Create one group for each videowall in a profile.
    1. Right-click a group in the Videowall tab.
    2. Select the desired videowall together with its main channel (the Viz output on which the videowall presets are run).
      images/download/attachments/58340564/image2020-4-15_7-52-57.png
    3. This group now only contains presets assigned to the selected videowall.
    Templates Tab
    images/download/attachments/58340564/image2017-11-3_15-59-12.png
    The Templates tab gives you access to Viz Pilot templates and elements.
    Note: In order to access the Templates Tab, Viz Pilot must be configured as a search provider in Settings > Servers Tab.
    Browse for a Viz Pilot template or an element. Right-click and select Preview to preview the graphics in a higher resolution.
    images/download/attachments/58340564/image2018-6-11_14-32-47.png
    Drag templates directly into your channels. This will automatically create a new Viz Pilot element.
    images/download/attachments/58340564/image2017-11-3_16-1-44.png
    The templates can be edited once they have been added to a channel (see Editing Graphics). Any changes made inside an element are visible immediately.
    Working with Data Elements
    Drag data elements from the Templates Tab into channels in the Media Column.
    This section covers:
    What are Data Elements?
    Data elements are variations of a template.
    For example, the same lower third may be used in both the morning and evening shows. Two different elements are created from a single template, each containing styling specific to the show for which it is created. The morning show element has a green lower third, while the evening show element has a red lower third.
    Where Can I Find Data Elements?
    Elements are accessible at the bottom of the templates tab. Drag them into channels in the same way as templates.
    images/download/attachments/58340564/usingvmp_elementswindow.png
    Refreshing the Data Elements List
    The data elements list is read out from the Pilot Data Server when a concept or a template is selected. This list does not change, even if someone is changing the list on the server. The list must therefore be refreshed manually.
    Refresh the List
    1. Right-click an element in the data elements list.
    2. Click Reload list.
      images/download/attachments/58340564/image2019-2-4_12-29-43.png
    The current subset of data elements is reloaded from the server.
    Filtering Data Elements
    Multiplay groups elements by concept and template.
    Note: It's not possible to filter data elements by category.
    View Elements by Concept
    Show all data elements belonging to all templates in a concept.
    1. In the Templates Tab, click the Concepts menu and select a concept.
      images/download/attachments/58340564/usingvmp_selectconcept.png
    2. Both templates (1) and elements (2) for the selected concept are listed.
      images/download/attachments/58340564/usingvmp_templatesconcepts.png
      Tip: Elements from concept is displayed to remind you that you are viewing elements associated with a concept.
    View Elements by Template
    Show all data elements belonging to a specific template:
    1. In the Templates Tab, click a template to view its elements.
      images/download/attachments/58340564/usingvmp_elementtemplate.png
    2. Here, Banner3 contains a single element titled Changed/Na....
    Note: Elements from template is displayed as a reminder that you are viewing elements associated with a single template.
    List and Grid View
    In the Templates Tab, click images/download/thumbnails/58340564/usingvmp_gridlist.png to view elements and templates in list or grid view.
