Day Switch Options
Activate Day Switch: Activates day switch for split playlists. The default Day Switch is 04:00. This can be changed in Channel Settings as required.
Insert Cleanup: Cleans up the program in Viz Engine a set amount of time before the day switch takes place.
Insert Initialize: Initializes the program in Viz Engine a set amount of time before the day switch takes place.
Note: Time is relative to the day switch action that is inserted as the last element of the day. For example, if the primary event ends 30 minutes after the preferred day switch time then the switch and all other actions are offset by 30 minutes to adjust for this.
