Importing from Excel
images/download/attachments/164954986/image-2024-5-31_20-0-20.png
The Excel module supports both *.xls and *.xlsx formats.
images/download/attachments/164954986/image-2024-5-31_20-2-54.png
The Excel sheet column is your Reference in the mapping table. For example, for column A set $A, and so on.
When working with Excel files, the first row should always be the header row, which must span all columns in use. The Skip Lines option should then be set to at least 1 as a value.
Enter $ and the letter representing the sequential column. You can call multiple columns/elements in a chain. You can also add characters to separate them. For example: $A / $G / $X
IMPORTANT! To use the Excel Import Type you must install Microsoft® Excel on the machine that imports the schedule file.
Note: There is a limitation of 100 columns when importing from Excel files.
