GET Channel Pool (Version 2.0)
By following the downlink from channel pool under a channel we can retrieve a channel's channel pool.
Syntax
GET /api/channels/[channel]/channel_poolRequest
GET /api/channels/test/channel_pool HTTP/1.1Response
HTTP/1.1 200 OKContent-Type: application/vizrt.integrationshubv2+xml; type=channelpool<inthub:channelPool xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:inthub="http://www.vizrt.com/integrationshub"> <inthub:name>channel_pool</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=channelpool" href="http://127.0.0.1:9991/api/channels/test/channel_pool" /> <inthub:refLink rel="events" type="application/vizrt.integrationshubv2+xml; type=list" href="http://127.0.0.1:9991/api/channels/test/channel_pool/events" /> <inthub:description>Channel Pool</inthub:description> <inthub:loaded>0.30</inthub:loaded> <inthub:available>0.50</inthub:available></inthub:channelPool>Disallowed Actions
This end-point does not allow POST, PUT or DELETE , and will return a 'HTTP/1.1 405 Method Not Allowed'.
