GET an Event in Channel Pool (Version 2.0)
Following the downlink while retrieving the collection of Events under channel pool one can also do a GET directly on a single Event.
Take note that the content depends on the type of Event, which can be of type Group Event or any type of Secondary Event.
Syntax
GET /api/channels/[channel]/channel_pool/events/[event]Request
GET /api/channels/test/channel_pool/events/element_1_0_0 HTTP/1.1Response
HTTP/1.1 200 OKContent-Type: application/vizrt.integrationshubv2+xml; type=event<inthub:event xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="inthub:groupEvent" xmlns:inthub="http://www.vizrt.com/integrationshub"> <inthub:name>element_1_0_0</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=event" href="http://127.0.0.1:9991/api/channels/test/channel_pool/events/element_1_0_0" /> <inthub:refLink rel="secondaryevents" type="application/vizrt.integrationshubv2+xml; type=list" href="http://127.0.0.1:9991/api/channels/test/channel_pool/events/element_1_0_0/secondaryevents" /> <inthub:refLink rel="edit" type="application/vizrt.integrationshubv2+xml; type=event" href="http://127.0.0.1:9991/api/channels/test/channel_pool/events/element_1_0_0" /> <inthub:description>Le radeau LE CRASH DU VOL 29</inthub:description> <inthub:startTime>2024-01-17T04:00:00.000Z</inthub:startTime> <inthub:duration>00:10:00.000</inthub:duration> <inthub:ignore>false</inthub:ignore> <inthub:triggerId /> <inthub:houseId /> <inthub:markIn /> <inthub:markOut /> <inthub:isLocked>false</inthub:isLocked> <inthub:isLive>false</inthub:isLive> <inthub:isManuallyEdited>false</inthub:isManuallyEdited> <inthub:available>1.00</inthub:available> <inthub:loaded>1.00</inthub:loaded> <inthub:infoIntegrationsHub /> <inthub:createdBy>manual</inthub:createdBy> <inthub:error /> <inthub:metadata /></inthub:event>Response
HTTP/1.1 200 OKContent-Type: application/vizrt.integrationshubv2+xml; type=event <inthub:event xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="inthub:pageEvent" xmlns:inthub="http://www.vizrt.com/integrationshub"> <inthub:name>element_2_0_0</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=event" href="http://127.0.0.1:9991/api/channels/test/channel_pool/events/element_2_0_0" /> <inthub:refLink rel="edit" type="application/vizrt.integrationshubv2+xml; type=event" href="http://127.0.0.1:9991/api/channels/test/channel_pool/events/element_2_0_0" /> <inthub:refLink rel="pagecontent" type="application/vizrt.integrationshubv2+xml; type=pagecontent" href="http://127.0.0.1:9991/api/channels/test/channel_pool/events/element_2_0_0/pagecontent" /> <inthub:description>The Smashing Pumpkins/Bullet With Butterfly Wings</inthub:description> <inthub:triggerId>element_2_0_0</inthub:triggerId> <inthub:offset /> <inthub:takeCount /> <inthub:createdBy>manual</inthub:createdBy> <inthub:infoIntegrationsHub /> <inthub:loaded>1.00</inthub:loaded> <inthub:available>1.00</inthub:available> <inthub:isManuallyEdited>false</inthub:isManuallyEdited> <inthub:duration /> <inthub:pageId>page0</inthub:pageId> <inthub:infoPromoServer /> <inthub:metadata /></inthub:event>Disallowed Actions
This end-point does not allow POST, and will return a 'HTTP/1.1 405 Method Not Allowed'.
