Viz Engine
Digital Voodoo DeepBlue LT
Digital Voodoo DeepBlue LT was used for standard definition Viz Trio No Video systems, typically on HP xw4200, xw4300 or xw4400 workstations.
IMPORTANT! Support for the DeepBlue LT card ended with Viz Engine 3.5. For supported versions, see the most recent BlueFish444 cards.
Caution: Only BlueFish444 v3.1 is guaranteed to support an adequate Ringbuffer-size. Any other driver will cut down or completely disable ring buffer support.
Configuration History
Viz Artist/Engine Version
Driver
3.6.3
Bluefish444 v5.10.2.18
3.6.1
Bluefish444 v5.10.2.4
3.5.1
Bluefish444 v5.10.1.11
3.5
Bluefish444 v5.9.0.78
3.2.7
Bluefish444 v5.9.0.25
3.2.2
Bluefish444 v5.7.6
3.1.0-3525
BlueFish444 v3.1
Note: Viz Engine 3.2.7 and 3.3.0 require the Bluefish444 v5.9.0.25 driver for all Digital Voodoo / Bluefish cards.
