Viz Engine
RTP Streaming
By using DSX Core or the Matrox M264 board, Viz Engine can send and receive RTP streams.
RTP streaming requires a Mezzanine IP license!
Receiving RTP Streams
The following configuration needs to be set to configure for RTP Stream Input:
  • GPUDirect should be turned OFF.
  • use_compositor should be 0.
  • a NTP server must be set. e.g. 131.107.13.100.
  • the color conversion rgb_2_yuv should be set to shader (=1).
  • The stream input should be set to e.g. 720P_5000_SMPTE296.
  • The StreamIn1.SrcUdpPort needs to be set to an even port number. e.g. 20000.
    Please note that port number should always be even.
  • StreamIn1.SrcAddress is the senders IP number.
  • StreamIn1.NICAddress is the IP address of your local network interface card that is going to receive the stream.
  • StreamIn1.AudioDecoderBufferSize should be set to 255.
  • StreamIn1.VideoDecoderBufferSize should be set to 255.
To simulate a 720p RTP stream to 10.211.1.26 you can use ffmpeg with the following parameters:
ffmpeg.exe -f lavfi -i smptehdbars=s=1280x720:r=50[out0] -c:v libx264 -profile:v high422 -pix_fmt yuv422p -x264-params "nal-hrd=cbr" -b:v 20M -minrate 10M -maxrate 10M -bufsize 10M -c:a aac -ac 2 -f rtp_mpegts -bsf:v h264_mp4toannexb rtp://10.211.1.26:20000
This will generate a test pattern in 720p and sends it to 10.211.1.26 on port 20000.
Sending RTP Streams
These are the required settings to generate a RTP Stream output from Viz Engine:
  • Set the output system to e.g. 720P_5000_SMPTE296.
  • Matrox0.VideoOut1.SrcUdpPort should be set to an even port number e.g. 10000.
  • Matrox0.VideoOut1.DstUdpPort is the destination port you want o use. e.g. 10002.
  • Matrox0.VideoOut1.DstAddress is the destination IP address you want to send to.
  • Matrox0.VideoOut1.NetworkInterfaceIPAddress must be your local NIC IP address.
To verify the correct output, you can use ffplay from ffmpeg tools:
ffplay rtp://{source IP of your Viz Engine}:{destination port} e.g. ffplay rtp://10.211.1.26:10002
