Viz Engine
Viz Artist/Engine Folders
This section details the location of the Viz Artist/Engine default installation and data folders.
Installation Folders
The default installation folders are:
Windows System
Viz Artist/Engine Platform
Installation Folder
Windows 64-bit
32-bit
C:\Program Files (x86)\vizrt\Viz3
64-bit
C:\Program Files\vizrt\Viz3\
C:\Program Files\vizrt\Viz3\artist (user Interface)
In this Administrator’s Guide, any reference to the Viz Artist and Engine installation folder, for example C:\Program Files\vizrt\Viz3, is replaced with the text <viz install folder>.
Note: Viz Config files that already exist from a previous installation are automatically copied on install time if the installation folder did not change. If Viz Engine/Artist is installed in a different installation folder then Viz Config files must be manually copied from the old installation folder to <viz data folder>.
Data Folders
Files which are created or modified by Viz Artist/Engine are located at %ProgramData%\vizrt\viz3, which usually resolves to C:\ProgramData\vizrt\viz3. This folder is referenced as <viz data folder> throughout this Administrator’s Guide, and contains, for example:
  • Viz Config files
  • Script plug-ins
  • Crash dump files
    Temporary files are located at: %TMP%\vizrt\viz3, which usually resolves to C:\Users\<user name>\AppData\Local\Temp\vizrt\Viz3. This folder is referenced as <viz temp folder> throughout this User Guide.
Script Plug-ins are located in the <viz data folder>\ScriptPlugins subfolder.
Note: Script Plug-in files that already exist from a previous installation are automatically copied on install time if the installation folder did not change. If Viz Engine/Artist is installed in a different installation folder then Script Plug-in files must be manually copied from the old installation folder to <viz data folder>\ScriptPlugins
