Viz Engine
HP Z4 G4
This section describes how to setup a HP Z4 G machine with the different cards provided by Vizrt.
More details about the HP Z4 G4 can be found on HP’s website: HP Z4.
images/e8201a68875c40df2c13a98e57252f2118a5fba68ad37899a01f9470ad3c9c29.dat images/efda2864faccbb24a18d3552e0303ef0d7185751885d94b484442806d63fd148.dat
Only newer Matrox Boards like xMio3 and DSX.LE4 are shipped with Z4 G4 workstations. Older videoboards are not tested by Vizrt.
PCI Configuration
images/download/attachments/37579192/image2018-6-12_10-57-33.png
Slot
Configuration
Slot 1
Graphics Card only! (Single / Dual Slot)
Slot 2
Used if Dual Slot GPU is installed
Slot 3
Possible Expansion Card Installation:
G-Sync
Blue Storm
Sea Level
Single Port Network Card
Video Cards (i.e. Matrox Video Boards)
Slot 4
Expansion Cards (see Slot 3, except Matrox Video Board)
Slot 5
Matrox AES Audio
Default Hardware
  • Tower 4RU
  • CPU Render: 1x Intel Xeon W-2102 (2.9GHz 4-Core)
  • CPU Control: 1x Intel Xeon W-2133 (3.6GHz 6-Core)
  • RAM Render: 32 GB DDR 4 (4x 8GB)
  • RAM Control: 16 GB DDR 4 (2x 8GB)
  • SSD1: 256 GB S-ATA (Operating System)
  • SSD2: 512 GB M.2 NVMe (Data and Clips, only in Render PC)
  • RAID Controller: Intel SATA/NVMe M.2
  • Power Supply: 1x 750W 90% Efficient
BIOS Configuration
  • During Post, press F10 to access BIOS Setup
  • Click “Advanced Tab” -> “Boot”: Enable Fast Boot
  • Go back to “Advanced TAB” -> “Secure Boot Configuration”
  • Select: “Legacy Support Disable and Secure Boot Enable”
  • Go back to “Advanced TAB” Overview and Click on “Build in Device”
  • Increase “PCIe Idle Fan Speed to: 0050
  • Press ESC and save Configuration
Certain third party vendor drivers require secure boot to be disabled to install properly.
