Viz Engine
Local Settings
images/download/attachments/41783944/cfg_audio_localsetting.jpg
  • Clip Data Directory: Set the clip directory (default directory is D:\ drive). Multiple directories can also be selected (see Select Multiple Directories)
    Note: This directory is also used for Viz One installations, as the root parameter for the Fsmon and Mediaftp services (see Viz One).
  • Verbosity: Select content of log files, if no selection is made only the default content of the log file will be created:
    • Verbose Output: Enables the most information in the Viz Engine Console.
    • Include Date and Time: Default content of the log file with the addition of date and time.
    • OpenGL Error Output (AMD): Default content of the log file with the addition of OpenGL Error Output (AMD).
    • GH Debug Log: Default content of the log file including Write GH Connection Log.
  • Post Default Path: Set the default location of Render to Disk clips.
  • Network Drive Linking: Enable to allow Viz Artist access to mapped network drives on certain systems where UAC is enabled.
  • Startup commands: Enter and save commands that will be executed on startup, but after the initial setup configuration and before the main render loop activates. Examples:
    FEEDBACK*CLIENT ADD localhost 2001
    FEEDBACK*COMMAND ADD localhost 2001 CLIPOUT
    RENDERER*MAIN_LAYER SET_OBJECT Vizrt_RD/mra/Reference/TC/TC_DISPLAY
    MAIN*DEBUG_CONTROL*RENDERINFO*PERFORMANCE SET 1
    Note: Log files will be written to the <viz data folder> directory, normally c:\ProgramData\Vizrt\viz3. This directory is by default hidden in Windows, so to navigate to this directory in Windows Explorer specify the explicit path. For more information see Viz Artist/Engine Log Files.
More than one clip directory can be selected.
When more than one directory path is selected in the Clip Name box, change the file path to <clip_root>. The included directories will be parsed when executing the search, returning video clips with file names matching the search criteria.
Example: Search for a video clip named next_tuesday.avi in D:\AEClips\AFL\Promos. In the Clip Name box, change D:\AEClips\AFL\Promos to <clip_root>. The filename displayed in Viz Artist should be <clip_root>\next_tuesday.avi.
Note: The directory has to match the directory set when the Mediaftp service for video transfer from Viz One was installed.
Multiple directories can be used with:
  • Dual Channel and Trio Box CG configurations, or
  • With any Viz Artist/Engine configuration for the selection of a secondary video clip directory if a directory fails.
    If the file path for a video clip is set to <clip_root> and the first directory fails, the same video file will be searched for in the next directory in the Clip directory list.
    If the Clip Name box is used to search for a video when multiple Clip directories are selected, the search will default to the last used directory.
SAM SDC01, SDC02, and SDC03 protocols
To enable or disable a supported SAM protocol please change the SAMSDC0x_enable. By default those protocols are switched off. The listening is changed with SAMSDC0x_address. If one needs to configure multiple instances those listening addresses need to be unique among the VizEngine instances.
SAM SDC01
## enable the SAM SDC01 protocol. This is disabled by default.
#* SAMSDC01_enable: Default=0
SAMSDC01_enable = 1
## the SAM SDC01 protocol listening endpoint.
#* SAMSDC01_address: Default=0.0.0.0:2055
# SAMSDC01_address = 0.0.0.0:2055
and
SAM SDC02
## enable the SAM SDC02 protocol. This is disabled by default.
#* SAMSDC02_enable: Default=0
SAMSDC02_enable = 1
## the SAM SDC02 protocol listening endpoint.
#* SAMSDC02_address: Default=0.0.0.0:2056
# SAMSDC02_address = 0.0.0.0:2056
and
SAM SDC03
## enable the SAM SDC03 protocol. This is disabled by default.
#* SAMSDC03_enable: Default=0
SAMSDC03_enable = 1
## the SAM SDC03 protocol listening endpoint.
#* SAMSDC03_address: Default=0.0.0.0:2057
# SAMSDC03_address = 0.0.0.0:2057
