Viz Engine
Matrox M264 S1/S2/S3
Matrox M264 cards feature hardware-based H.264 encoding and decoding capabilities. Depending on the card used, up to three UHD XAVC streams can be encoded/decoded simultaneously.
VizEngine as well as ChannelRecorder are capable of using the M264 cards for playback and capture of XAVC material, without affecting CPU performance.
images/download/attachments/41789413/M264.jpg
Key features
  • PCI Express Cards
  • H.264 video encoding and decoding
  • UHD resolution support
  • 4:2:2 10-bit
  • Sony XAVC compliant encoding including 4K XAVC Long and 4K Intra Class 480
  • Panasonic AVC-Ultra compliant
Performance for 4:2:2 10-bit streams for M264
Resolutions
Structure
Format
Number of streams
2160p
I-frame
XAVC Class 300 & Class 480 / AVC-Intra 4K
1
1080p
I-frame
XAVC Class 200 / AVC-Intra 200
3
1080i
I-frame
XAVC Class 100 / AVC-Intra 100
10
2160p
Long GOP
Generic / XAVC 4K Long
1
1080p
Long GOP
Generic / XAVC Long50 / AVC-LongG50
5
1080i
Long GOP
Generic / XAVC Long25 / AVC-LongG25
10
720p
Long GOP
10
The models S2 and S3 host (respectively) two and three encoder/decoder chips, so the number of possible streams is doubled/tripled.
M264 configuration
VizEngine
To enable VizEngine to use M264 cards, the serial number of the M264 needs to be added to the configuration file after the serial number of the installed X.mio3 or DSX LE 4 card.
Matrox.Devices = A123456,A654321
ChannelRecorder
ChannelRecorder detects any installed M264 card automatically and uses it for encoding, when the XAVC UHD codec is used. No further configuration is necessary.
GPU Direct currently is not supported in combination with M264 hardware.
