Viz Engine
Mixed Mode Video Support
This section gives an overview of the Matrox’ mixed mode video support. The tables are valid for both genlock families in Viz Engine. One is 25/50 (e.g. PAL/720p50/1080i25/1080i50) and the other is 30M/60M (e.g. NTSC/720p60M/1080i30M/1080i60M).
The genlock family refers to the used house signal (e.g. black burst) frequency - typically PAL for the first and NTSC for the latter. Please observe that genlock families can not be mixed.
The following contain information on the following topics:
Source: PAL or NTSC
The first two tables show video in to DVE and texture output capabilities, while the next two tables show clip in to DVE and texture output capabilities. Please observe that genlock families can not be mixed.
Video In to DVE and Texture
Output DVE
Video In
PAL/NTSC
720p
1080i
PAL/NTSC
OK
720p
1080i
OK
Output Texture
Video In
PAL/NTSC
720p
1080i
PAL/NTSC
OK
720p
OK
1080i
OK
Clip In to DVE and Texture
Output DVE
Clip In
PAL/NTSC
720p
1080i
PAL/NTSC
OK
720p
OK
1080i
OK
OK
Output Texture
Clip In
PAL/NTSC
720p
1080i
PAL/NTSC
OK
720p
OK
OK
1080i
OK
OK
OK
Source: 720p
Output DVE
Video In
PAL/NTSC
720p
1080i
PAL/NTSC
720p
OK
1080i
OK
Output Texture
Video In
PAL/NTSC
720p
1080i
PAL/NTSC
OK
720p
OK
1080i
OK
Output DVE
Clip In
PAL/NTSC
720p
1080i
PAL/NTSC
OK
720p
OK
1080i
OK
OK
OK
Output Texture
Clip In
PAL/NTSC
720p
1080i
PAL/NTSC
OK
OK
720p
OK
OK
1080i
OK
OK
OK
Source: 1080i
The first two tables show video in to DVE and texture output capabilities, while the next two tables show the clip in to DVE and texture output capabilities. Please observe that genlock families can not be mixed.
Output DVE
Video In
PAL/NTSC
720p
1080i
PAL/NTSC
720p
1080i
OK
Output Texture
Video In
PAL/NTSC
720p
1080i
PAL/NTSC
OK
720p
OK
1080i
OK
Output DVE
Clip In
PAL/NTSC
720p
1080i
PAL/NTSC
OK
720p
OK
1080i
OK
OK
OK
Output Texture
Clip In
PAL/NTSC
720p
1080i
PAL/NTSC
OK
OK
720p
OK
OK
OK
1080i
OK
OK
OK
