Viz Engine
Legacy Cards
This section contains an overview of legacy and discontinued hardware. Vizrt does not support the hardware described in this chapter. Refer to this section only if you are configuring an older version of Viz Engine, or for maintenance purposes.
Caution: Vizrt does not perform any system tests using the hardware in this chapter. Using newer versions than listed of Viz Engine, Viz Artist, operating system or drivers, may cause unexpected behavior or system failure.
