Viz Engine
Pinnacle Targa 3200
Pinnacle Targa 3200 was Vizrt’s standard card for SD Viz systems until 2007, and was typically used with IBM ZPro 6221, IBM Z-Pro 6223 and HP xw8200.
Configuration History
Driver
Revision
CODI v2.42
3213. Revision 3213 crashes the machine when used with CODI v2.41rc13.
CODI v2.41rc13
3212, 3214. Installation of CODI Compatibility Patch for revision 3214 is no more required.
CODI v2.42
3212, 3213, 3214. Installation of CODI Compatibility Patch is required.
CODI v2.2 RC4
3212, 3213
