Viz Multiplay User Guide
Version 2.5 | Published February 18, 2019 ©
Known Issues
Known issues in Viz Multiplay:
Thumbnails for graphics with video texture will only display the graphic.
Running Cleanup also cleans up the Presets scene. Therefore, after a cleanup, you must run a Preset before running other elements. To do this, click on a Preset.
Do not initialize while one air, as this can result in a lag in the graphics output.
If a playlist is activated by a Viz Trio client, then it will be deactivated if that Viz Trio client shuts down, and Viz Multiplay will lose its active profile. Always set the Active Profile for a playlist in Viz Multiplay.
Viz Multiplay does not support videos with overlay graphics as a timeline. To display graphics on top of videos, place GFX channels on top of each other an play elements manually in each channel.
Using color correction together with a bezel in the NVIDIA Mosaic setup will require Viz Engine 3.8.3.
