Viz Vectar Plus User Guide
Version 1.2 | Published April 12, 2022 ©
Control Surfaces
This section introduces the Viz Vectar Plus control surfaces, describing how they complement your system's production setup. Connecting your live production system to the control surface is also covered.
Viz Vectar Plus provides unrivaled live production power. With a matching control surface, all that power is right at your fingertips.
Two Viz Vectar Plus control surfaces have been prepared for varied requirements. In large measure the functionality provided, and workflow is identical, regardless of which you use.
  • Vizrt quad row panel is a large and powerful four-stripe unit, delivering precise control over your program, allowing you to quickly and confidently produce your show.
  • Vizrt dual row panel is its more compact sibling.
