Viz Vectar Plus User Guide
Version 1.2 | Published April 12, 2022 ©
Transitions and Effects
This section presents layout and use of the Transition controls.
See also section Background and DSK Layers.
Animated Store Transitions‌
Viz Vectar Plus can also employ special transition effects called Animation Stores.
  • These powerful effects normally include an embedded full color animated overlay, along with sounds for transitioning in and out (sounds are optional).
  • The audio level for Effects is controlled in the Audio Mixer tab below the Switcher.
  • Animation Store transitions are loaded into the Transition Palette in the same way as simpler transitions, using the Browse feature.
  • Some Animation Store transitions contain custom animation content you have to access to can only be modified with third party software.
Note: The Animation Store Creator application is covered in its own manual, available from the Help menu on the Viz Vectar Plus startup screen.
Standard Mode Switcher Operations
With the Switcher in its standard mode, multiple operations are available.
At left in this group are the main Transition controls, including the T-bar. The control groups right of the T-Bar provide configuration and control options for the individual DSK layers.
images/download/attachments/92971693/image2022-3-11_10-38-44.png
DSK Controls
Each DSK layer has a live video viewport showing the current source assigned to it (using the menu at right above the viewport) and its own transition effect. Click the transition icon at lower left below the viewport to reveal a palette of different transition presets provided for quick selection. Click an entry in the palette to select it, or move the mouse pointer to the + sign that pops up for each icon and click to open the Custom Media Browser.
Tip: The frequently-used Cut and Fade effects always available in the transition palette. As these cannot be replaced, no + sign appears for these icons.
In the Media Browser, you can choose from hundreds of transition effects. The selected effect replaces the current one in the palette. To display or hide the DSK video layer over the BKGD layer on Program output using the currently selected effect, click (or tap) the viewport or the effect name label just below.
Tip: You can halt an unfinished effect by clicking again during the transition. Click it again to continue performing the effect.
Transition Delegates
images/download/thumbnails/92971693/image2022-3-11_10-39-53.png
You can also control transition progress using the Switcher’s T-Bar control, at left. The T-Bar operates on all delegated video layers. To delegate a DSK, click its label at upper left () to turn it blue. Clicking it a second time un-delegates the layer. The T-Bar acts on all delegated layers, including the Background video layer. For example, if DSK 1 is visible, but DSK 2 is not, when both DSKs and BKGD are delegated performing a T-Bar (or BKGD AUTO) operation reverses the visibility of the two DSKs on Program output when the BKGD transition occurs.
Transition Timing
images/download/thumbnails/92971693/image2022-3-11_10-40-43.png
Per transition timing is set and stored in the effect palette, using the numeric duration control beside the effect icon. Select transition speeds using the menu below the Transition Palette. You can also drag the mouse pointer over the numeric display to set a custom time, or click it to enable keyboard entry of the effect duration.
Tip: The direction of Transitions applied as DSK (and M/E KEY) layer effects automatically alternates. If the first click displays the layer using an effect, the next click removes it using the reverse effect.
DSK Source Configuration
images/download/thumbnails/92971693/image2022-3-11_10-41-13.png
Many more configuration options are available for DSKs (and their siblings, M/E key layers, too). To access these settings and features, roll the mouse pointer over the DSK viewport, and click the configuration (gear) gadget that appears at lower right.
Tip: Touchscreen users can two-finger tap the viewport to open the Configuration panel.
Doing so opens the Input Configuration panel for the source assigned to the DSK, but with the addition of a supplemental tab labeled DSK (1-4). The control groups in this new tab expand to reveal Position, Use Source Tracker and Borders, Edges and Shadows settings.
Position and Crop
images/download/attachments/92971693/image2022-3-11_10-41-47.png
  • The Position control group includes Position, Zoom, Rotation, and Priority. Position settings can be toggled on and off together using the switch provided in the group header.
  • Click and drag on the Position button (diamond) to relocate the DSK layer vertically or horizontally within the frame.
  • Drag left or right on either of the two nearby numeric controls to adjust a single axis only. Dragging the cursor on the Zoom button (magnifying glass) affects the apparent size of the overlay.
  • If you drag just one of the associated numeric gadgets you can adjust just one dimension of the corresponding DSK layer – width or height.
  • In similar fashion, drag the pointer over the Rotation button with the left mouse button depressed to turn the overlay source on three axes as follows:
    • Drag left/right to rotate the source about the Y (vertical) axis.
    • Drag up/down to rotate about the X (horizontal) axis.
    • Drag while holding ALT down to rotate about the Z axis.
    • Drag on a single numeric slider, or hold down CTRL to constrain rotation to one axis.
Tip: If you click a numeric field (or right-click it), you can type a value into the gadget using the keyboard; press ENTER to complete the editing action, or ESC to cancel it).
The Crop DSK/KEY controls in this group are similar to those found in the Input tab, as discussed in Input Configuration. However, these settings are applied to the DSK/KEY layer, without any impact on the source itself as it may be displayed elsewhere in the Switcher.
Info: DSK and KEY layers automatically appear on the Preview and (M/E Preview) monitors when the Position panel is open (regardless of layer display options). This allows you to modify a layer’s position without the result being inadvertently shown on output.
Z-Priority
Normally, KEY and DSK layers appear in numeric order from back (furthest from the viewer) to front. This if DSK 1 and DSK 2 are both displayed and occupy the same position in the frame, the content in DSK 2 occludes DSK 1.
images/download/thumbnails/92971693/image2022-3-11_10-43-31.png
The Z-Priority setting in DSK and KEY layer positioning panels allows you to revise the default layer order on a selective basis. This feature was specially implemented to provide additional flexibility for use with the COMPS feature.
For example, imagine an M/E set up with 4 KEYs supplying a quad-box setup for four remote interviewees over a background supplied by the M/E. You might want to use Comps to zoom the top-left input up to fill the screen while the moderator chats with that person. Normally, KEYs 1-3 would always appear behind KEY 4 – not what you want at all. Z-Priority lets you move any KEY to the front (and the setting is stored in your Comps).
The range of Z-Priority settings runs from -10 to +10, with a default 0. A layer with a higher index is shown in front of those with lower indices. When two layers have the same layer priority, they are rendered in their natural (DSK/KEY layer) order.
Apply with Comp
images/download/thumbnails/92971693/image2022-3-11_10-43-41.png
We will discuss the powerful Comp system a bit later, but we’ll mention it in passing here to highlight the Apply with Comp switch provided in the Position control group. At the lowest level, Comps can be thought of as presets that store complete Switcher or M/E setups.
By default, the settings stored in a Comp include the Position, Crop and visibility state for each DSK or KEY layer. Disable the Apply with Comp feature if you want to exclude a given DSK/KEY channel from Comp control, handling it manually instead.
Tip: You might find this useful, for example, to ensure that a station ID bug shown over output is not accidentally removed by application of a Comp.
Use Source Tracker
images/download/thumbnails/92971693/image2022-3-11_10-44-14.png
We discussed the video Tracker in Input Configuration. The Use Source Tracker feature lets you assign motion data output from the Tracker for any video source to modify the position of the current DSK or KEY layer by selecting it in this menu. Position settings enabled above in the DSK/KEY tab continue in force but is applied relative to Tracker output. For example, X and Y Position settings entered in the upper part of the panel result in an offset from the co-ordinates supplied by the Tracker.
images/download/attachments/92971693/image2022-3-11_10-44-35.png
The Borders, Edges and Shadows group also provides each DSK, KEY and M/E layer with three quick access border preset slots.
Tip: Since these are per-layer Position effects and can be controlled – even animated – by Comps, you can use the Borders feature to create custom multi-box compositions in M/Es.
These powerful effects can include full color overlays, backgrounds, matte layers for keyhole effects, and shadows.
  • You can freely scale, position and rotate various Switcher sources, add custom borders, overlays, shadows, and so-on, over custom backgrounds.
  • In addition to hundreds of supplied borders, you can easily create elaborate custom effects using Adobe Photoshop™.
    • Define a Photoshop™ format file with three (rasterized) layers.
    • The uppermost layer contains foreground elements (such as a bezel).
    • The next layer is treated as a mask based on opacity and defines the part of the source image that appear in the result.
    • The bottom layer supplies a background to appear behind transparent parts of the source (as, for example, when LiveMatte is applied to a source).
      images/download/attachments/92971693/image2022-3-11_10-45-22.png
A template PSD file is supplied to assist you to do this. The multi-layer Photoshop™ file is in the Borders folder at C:\ProgramData\vizrt\Effects\Borders.
Tip: Since the opacity of the mask layer can vary between fully opaque and fully transparent, you can easily prepare soft-edged effects such as vignettes. Also, as foreground and background layers can optionally be empty, a simple opaque shape in the mask layer can serve a variety of imaginative purposes.
Transparency
Sources assigned to DSKs are often partially transparent. This might be because they are drawn from a Media Player (DDR) file that includes an embedded alpha channel, or because LiveMatte or Crop options are enabled for the source, or perhaps because a Network source includes an alpha channel, or even all of these factors operating together.
In all of these cases, DSK layers automatically respect transparency when supplied by the source. The BKGD layer and all visible content in lower-numbered DSKs appear through or around sources with transparency as appropriate.
Important: It’s best to use files with straight (non-premultiplied) alpha channels for Viz Vectar Plus media players. Premultiplied files generally do not yield correct results when overlaid on other imagery.
images/download/thumbnails/92971693/image2022-3-11_10-45-36.png
DSK layers offer a lot of creative possibilities. You might use DSK channels to display a permanent station ID bug, superimpose a company logo onto a title page, perhaps to add a spinning globe animation playing in the DDR to a lower-third, frame a keyed source composed over a title, or set up many other elaborate effects in this manner.
Background Controls
images/download/thumbnails/92971693/image2022-3-11_10-46-0.png
The QuickSelect button (marked with an Eye icon to associate it with visibility) is located in between BKGD and FTB.
  • Click to update the Switcher's T-Bar delegate and transition states so that the next TAKE or AUTO operation will remove all visible DSK or KEY layers from output.
    (On supporting control surfaces, press ALT and BKGD to trigger the QuickSelect feature).
Background Transition Group
Transition controls in this section apply to the Background video layer only. In most respects, these tools are identical to the DSK transition controls discussed earlier, but there is one difference worth mentioning.
images/download/thumbnails/92971693/image2022-3-11_10-46-18.png
The Duration menu for the Background transition offers two items not included in the similar DSK/KEY controls:
  • Reverse: Configures the current transition to run in reverse direction the next time it is applied.
  • Ping Pong: Causes the direction of the transition to be automatically swapped after each time it is applied.
FTB
images/download/thumbnails/92971693/image2022-3-11_10-46-40.png
The acronym stands for Fade to Black. FTB offers a convenient method of doing what its name implies – fading Program output completely to black. It might help to think of FTB as a final video layer added above all others before Program output, completely obscuring everything below it.
As a memory aid, the FTB button pulses during operation. FTB’s fade duration is drawn from the BKGD transition setting.
Note: Hold down SHIFT while pressing the FTB button on a control surface to initiate an FTB operation. Hiding or displaying FTB triggers both Autoplay and Audio Follow Video when enabled for Media Players. It also fades Master Audio to mute when displayed, and back up again when hidden.
Take and Auto
images/download/thumbnails/92971693/image2022-3-11_10-47-15.png
Clicking the Background layer’s Take button (keyboard shortcut ENTER) performs a straight cut for all video layers that are currently delegated. Likewise, if you press Auto (or the keyboard SPACEBAR), the transitions assigned to all delegated video layers are performed.
Tip: You can halt an Auto operation partway by clicking the button a second time during the transition. The operation is completed the next time you click the button.
T-bar
The T-bar mimics the similar control on a traditional video switcher and allows you to manually transition between selected video layers. To use the T-bar, pull it downward by dragging it with the mouse pointer. Drag it all the way to the bottom and release to complete a transition; the T-bar then pops back to the top.
Tip: When the T-bar is dragged part way, a partial transition occurs. With certain transitions this can be useful for split screen effects.
Express Mode Switcher Operations
Express mode presents a simpler view of the Switcher, intended for less complex productions.
  • To open Express mode, click or tap the EXPRESS tab at right above the Switcher.
    images/download/attachments/92971693/swExp.png
images/download/thumbnails/92971693/image2022-3-11_10-48-16.png
Note the quad-selector located between the single Switcher row, and the DSK controls at right. Cut and Crossfade mode buttons top this control group.
  1. Click or tap either the Cut or Crossfade button to activate the corresponding Background transition.
    Just below these you see two selectable transition controls.
  2. Tap or click these to activate the effect represented by the icon as the current Background transition instead.
  3. To open a transition selector to choose a different transition for either of these slots, click the gear that appears at lower right when your mouse pointer is over the icon.
Tip: Although the gear is not visible in a touchscreen scenario, you can still tap the lower right corner of the icon to open the transition bin.
Switching
  1. Selected the Background transition.
  2. Click or tap the button for the source you wish to send to Program output.
    There is no need to make a Preview row selection first, as you would need to do in the standard (two-row) Switcher.
  3. The Background transition you chose is applied to display the new source.
DSKs
The two DSK control groups at right work just like the Standard Mode Switcher, but it is particularly handy that you need to click or tap their viewport to show or hide the associated DSK layer.
