![](assets/images/logos/VizMultichannelLogo.png)
Viz Multichannel
D-Series by Harris Broadcast
This section describes configuring the Playout Automation for Enterprise Environments system (D-Series) by Harris Broadcast to work with Viz Multichannel:
General Information and Setup
On the Viz Multichannel side it is similar to the ADC-100 setup; however, Universal Sercom Device is not available, and the LST file provided by the D-Series is not binary but text file based.
Updating Live
VICC: D-Series automatically generates text format *.VICC files into a drop-folder, a line per primary event (secondary events in the primary event’s line). Viz Multichannel can scan that folder and update playlists accordingly.
Limitations
VICC file size is limited so it may not contain all events in the playlist but only a portion of them.
VICC file will not provide all the information available in scheduling system.
Maximum number of playout channels exported = 25
Maximum number of schedule events exported per channel = 1000
Maximum number of as ran events exported per channel = 50
Maximum number of fields exported per event = 16
Maximum length of each event record = 256 characters
