![](assets/images/logos/VizMultichannelLogo.png)
Viz Multichannel
Reading Channel and Date Values from Filenames
Whenever your collected schedule does not contain channel and date values you can extract that information based on the schedule’s file name.
Viz Multichannel can read these two fields from the imported filename when using Importing from Text, Importing from XML, Importing from Excel, or Harris ADC-100.
In order to read these fields from the filename, set their mapping to $Filename and define the filename format in the Schedule File Name Info parameter in the Mapping Settings.
The file format should contain D/M/Y to represent the day/month/year character location in the file name, and C to represent the character locations of the channel name in the file name. Characters that do not belong to the channel/date can be written as any character except for D/M/Y/C.
For a filename Channel10_20090627.txt, set Schedule File Name Info to CCCCCCCCC_YYYYMMDD or CCCCCCCCC_YYYYMMDD.txt.
