Viz Multichannel
GET Primary Events in Playlist (Version 2.0)
By following the downlink from the description of a single playlist we can retrieve a collection of primary events.
Take note that the collection of entries under meta_data sub-section is not set in size or content, and depends on the actual meta data attributes on the primary events in the playlist.
Syntax
GET /api/channels/test/playlists/continuous/primaryeventsRequest
GET /api/channels/test/playlists/continuous/primaryevents HTTP/1.1Response
HTTP/1.1 200 OKContent-Type: application/atomsvc+xml<atom:feed xmlns:vaext="http://www.vizrt.com/atom-ext" xmlns:vizid="http://www.vizrt.com/opensearch/vizid" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:inthub="http://www.vizrt.com/integrationshub" xmlns="http://www.w3.org/2007/app" xmlns:atom="http://www.w3.org/2005/Atom"> <atom:entry> <inthub:name>1051111_1_VM_16_01_1</inthub:name> <atom:id>1051111_1_VM_16_01_1</atom:id> <atom:link rel="self" type="application/atom+xml; type=entry" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/1051111_1_VM_16_01_1" /> <atom:link rel="edit" type="application/atom+xml; type=entry" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/1051111_1_VM_16_01_1" /> <atom:link rel="secondaryevents" type="application/atom+xml; type=feed" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/1051111_1_VM_16_01_1/secondaryevents" /> <atom:meta_data> <atom:attribute name="continue_count">0</atom:attribute> <atom:attribute name="created">6/11/2018 17:33:51</atom:attribute> <atom:attribute name="date">2010-09-23</atom:attribute> <atom:attribute name="fixed_duration">yes</atom:attribute> <atom:attribute name="seqment">1</atom:attribute> <atom:attribute name="time">08:50:15:24</atom:attribute> </atom:meta_data> <inthub:description>In-channel trailer</inthub:description> <inthub:begin_at>2018-11-06T07:13:40.000Z</inthub:begin_at> <inthub:duration>00:00:35:00</inthub:duration> <inthub:ignore>False</inthub:ignore> <inthub:event_id>1051111_1_VM_16_01_1</inthub:event_id> <inthub:trigger_id>1051111_1_VM_16_01_1</inthub:trigger_id> <inthub:instance>composite_test</inthub:instance> <inthub:adjust_begin_at_after_resume>yes</inthub:adjust_begin_at_after_resume> <inthub:isManuallyEdited>true</inthub:isManuallyEdited> <inthub:available>1.00</inthub:available> <inthub:loaded>1.00</inthub:loaded> <inthub:take_count>0</inthub:take_count> <inthub:infoIntegrationsHub>[A:13:27:24]</inthub:infoIntegrationsHub> </atom:entry> <atom:entry> <inthub:name>1053845_2_VM_16_01_1</inthub:name> <atom:id>1053845_2_VM_16_01_1</atom:id> <atom:link rel="self" type="application/atom+xml; type=entry" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/1053845_2_VM_16_01_1" /> <atom:link rel="edit" type="application/atom+xml; type=entry" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/1053845_2_VM_16_01_1" /> <atom:link rel="secondaryevents" type="application/atom+xml; type=feed" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/1053845_2_VM_16_01_1/secondaryevents" /> <atom:meta_data> <atom:attribute name="continue_count">0</atom:attribute> <atom:attribute name="created">6/11/2018 17:33:51</atom:attribute> <atom:attribute name="date">2010-09-23</atom:attribute> <atom:attribute name="fixed_duration">yes</atom:attribute> <atom:attribute name="seqment">1</atom:attribute> <atom:attribute name="time">09:30:04:24</atom:attribute> </atom:meta_data> <inthub:description>News Today</inthub:description> <inthub:begin_at>2018-11-06T11:30:00.000Z</inthub:begin_at> <inthub:duration>00:25:00:00</inthub:duration> <inthub:ignore>False</inthub:ignore> <inthub:event_id>1053845_2_VM_16_01_1</inthub:event_id> <inthub:trigger_id>1053845_2_VM_16_01_1</inthub:trigger_id> <inthub:instance>composite_test</inthub:instance> <inthub:adjust_begin_at_after_resume>no</inthub:adjust_begin_at_after_resume> <inthub:pause_after_scheduling>yes</inthub:pause_after_scheduling> <inthub:isManuallyEdited>true</inthub:isManuallyEdited> <inthub:available>1.00</inthub:available> <inthub:loaded>1.00</inthub:loaded> <inthub:take_count>0</inthub:take_count> <inthub:infoIntegrationsHub>[U:13:49:12]</inthub:infoIntegrationsHub> </atom:entry></atom:feed>
