Viz Multichannel
GET Playlist in Channel (Version 2.0)
By following the downlink from the collection of playlists under a channel we can retrieve a single named playlist.
Syntax
GET /api/channels/test/playlists/continuousRequest
GET /api/channels/test/playlists/continuous HTTP/1.1Response
HTTP/1.1 200 OKContent-Type: application/atomsvc+xml<atom:entry xmlns:vaext="http://www.vizrt.com/atom-ext" xmlns:vizid="http://www.vizrt.com/opensearch/vizid" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:inthub="http://www.vizrt.com/integrationshub" xmlns="http://www.w3.org/2007/app" xmlns:atom="http://www.w3.org/2005/Atom"> <inthub:name>continuous</inthub:name> <atom:id>continuous</atom:id> <atom:link rel="self" type="application/atom+xml; type=entry" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous" /> <atom:link rel="edit" type="application/atom+xml; type=entry" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous" /> <atom:link rel="refresh" type="application/atom+xml; type=entry" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/refresh" /> <atom:link rel="primaryevents" type="application/atom+xml; type=feed" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents" /> <atom:link rel="state" type="application/atom+xml; type=feed" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/state" /> <atom:meta_data /> <inthub:description>Continuous Playlist</inthub:description> <inthub:broadcastDate>continuous</inthub:broadcastDate> <inthub:import_file>D:\Schedules\20100923_demo.txt</inthub:import_file></atom:entry>
