Viz Multichannel
GET Playlist State (Version 2.0)
Retrieve the state-information of a playlist.
Syntax
GET /api/channels/test/playlists/continuous/stateRequest
GET /api/channels/test/playlists/continuous/state HTTP/1.1Response if playlist is RUNNING
HTTP/1.1 200 OKContent-Type: application/atomsvc+xml<atom:entry xmlns:vaext="http://www.vizrt.com/atom-ext" xmlns:vizid="http://www.vizrt.com/opensearch/vizid" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:inthub="http://www.vizrt.com/integrationshub" xmlns="http://www.w3.org/2007/app" xmlns:atom="http://www.w3.org/2005/Atom"> <inthub:name>continuous</inthub:name> <atom:id>_slash_VizRundown_slash_channels_slash_test_slash_playlists_slash_continuous</atom:id> <atom:link rel="self" type="application/atom+xml;type=entry" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/state"/> <inthub:description>Continuous Playlist</inthub:description> <inthub:playlist>/VizRundown/channels/test/playlists/continuous</inthub:playlist> <inthub:user>NN</inthub:user> <inthub:state>running</inthub:state></atom:entry>Response if playlist is STOPPED
HTTP/1.1 200 OKContent-Type: application/atomsvc+xml<atom:entry xmlns:vaext="http://www.vizrt.com/atom-ext" xmlns:vizid="http://www.vizrt.com/opensearch/vizid" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:inthub="http://www.vizrt.com/integrationshub" xmlns="http://www.w3.org/2007/app" xmlns:atom="http://www.w3.org/2005/Atom"> <inthub:name>continuous</inthub:name> <atom:id>_slash_VizRundown_slash_channels_slash_test_slash_playlists_slash_continuous</atom:id> <atom:link rel="self" type="application/atom+xml;type=entry" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/state"/> <inthub:description>Continuous Playlist</inthub:description> <inthub:playlist>/VizRundown/channels/test/playlists/continuous</inthub:playlist> <inthub:user>NN</inthub:user> <inthub:state>stopped</inthub:state></atom:entry>
