![](assets/images/logos/VizWorldLogo.png)
Viz World User Guide
Map Builder Plugin
The plugin can be found in the folder: Viz Artist 3: Built Ins -> Scene Plugins -> Maps.
The Map Builder solution consists of 2 major parts:
Map Builder Plugin – is a Viz Artist scene plugin that builds a scene from a map template (*.mtpl) file, and saves the map scene changes to the map template file.
Map Builder – is a wizard-like solution, with a simple and easy interface to create generic map scenes. Map Builder allows the user to create a scene descriptor (*.mtpl files) that represents a map scene and its containing elements. The Map Builder is accessible through the Map Builder scene plugin, and as a standalone application.
Properties
Map Template Filename: Sets the name of the scene template file or click the browse button to select a file.
Rebuild Scene: Updates the scene tree with changes from the Map Builder.
Launch Wizard: Runs the Map Builder application.
Clean Scene: Cleans the scene hierarchy.
Build Scene From Scratch: Cleans the scene tree and rebuilds the scene hierarchy using the defined map template file.
